DIY 360 Surround Parking Camera
Old May 8, 2021 | 07:50 AM
PowersFilm's Avatar
PowersFilm
Default DIY 360 Surround Parking Camera
Has anyone successfully installed a 360 "Panoramic" Parking Camera? I just purchased a brand new, 2021 Lexus Premium GX 460 and unfortunately the 360 camera is only included in the Luxury package.
I have seen and read of people installing their own DIY Surround Parking cameras systems, but I have a few questions:
- Can the custom cameras be displayed on the stock Infotainment screen?
- Is it worth the hassle?
- Can you do it for around ~$2,000?
Here are a few systems I have been looking at:
Amazon Amazon
Has anyone had any success installing something like this in a 2021 or 2020 Lexus GX460?
Thanks!
Old May 8, 2021 | 08:35 AM
hzhao's Avatar
hzhao
25 Year Member
Here is what I have done for 2014 GX in regards of 360 view. You can find many other mods under sticker threads for maintenance and mods above:
https://www.clublexus.com/forums/gx-...completed.html
Old May 9, 2021 | 07:41 AM
PowersFilm's Avatar
PowersFilm
Quick Update:
Has anyone had any luck installing this unit? Some people have recommended it.
Amazon Amazon
Old May 9, 2021 | 07:54 AM
WRD4chano's Avatar
WRD4chano
Originally Posted by PowersFilm
Quick Update:
https://www.amazon.com/dp/B0105XR91O...ing=UTF8&psc=1
the only person on this board who has done anything close to what you're asking about posted above you.
Old May 9, 2021 | 07:56 AM
hzhao's Avatar
hzhao
25 Year Member
Quick Update:
All of those units are similar, many are using the same original components just different badging and different brand names.
Old May 9, 2021 | 09:23 PM
crwys's Avatar
crwys
Amazon Amazon
I installed this in my 2014 GX. I have an aftermarket stereo though so I can't comment on the experience using it with the stock stereo.
To be honest I wish the camera quality was better, its still pretty good but if I was going to do it again I would buy a more expensive unit if there is one out there. I installed it my self, took about 11-12 hours of my day, the most challenging part was doing the wiring from the mirrors. My backup camera before this was also aftermarket and definitely better quality. It is useful doing parallel parking and definitely a "cool" factor. Its always recording when the car is turned on so that's also nice for insurance purposes if you ever get in an accident.
Mine is setup to always show when the car is in reverse (luckily the aftermarket stereo allows you to turn off the guidelines so it only shows one guideline) and I can also view the cameras at any through an app on my aftermarket stereo.
Old May 12, 2021 | 10:53 AM
sinistar's Avatar
sinistar
Did Beatsonic fix the issue where the front camera becomes disabled if the battery is disconnected, requiring you to pull the dash to get it to work again? That was a deal breaker for me.
Old May 12, 2021 | 02:18 PM
hzhao's Avatar
hzhao
25 Year Member
It hasn’t as far as I know. I have installed a reset switch under the dash, so far I only need to reset once when I replaced battery. The switch purpose is to by pass the beatsonic switch and send video signal to EUC. It is not really the beatsonic issue rather the Park Assist EUC. When EUC resets from power lose, if there is no reverse camera video signal detected, it will not trigger a switch signal to display as the system “assumed” there is no backup camera available. As soon as a video signal has been supplied, the EUC status and trigger is restored.
Old Apr 14, 2022 | 07:57 PM
Ramzizaz's Avatar
Ramzizaz
8th Gear
Not sure if it makes a difference but will either method from hzhoa or the amazon one work with an earlier 2010 GX460. I know the beatsonic does not work pre 2014. Sorry if this has been asked before but could not find the answer with search.
Old Apr 15, 2022 | 06:42 AM
hzhao's Avatar
hzhao
25 Year Member
All of those will work with 2010 GX. The only thing that you need to modify with Beatsonic switch component would be re-mapping the reverse video signal, reverse trigger signal from the OEM head unit harness. Since the Beatsonic only make the plug and play harnesses for 2014+ GX, and prior years GX has different OEM head unit and harness. However, the concept and signal wiring are all the same for it to be functioning.
SpruceRain
Jun 14, 2019 06:44 AM
choff
Sep 8, 2018 09:05 AM
dbahelp
GX - 2nd Gen (2010-2023)
Nov 12, 2015 03:41 PM
looknow12
GX - 1st Gen (2003-2009)
12
Feb 25, 2004 09:38 AM
