View Poll Results: Do you see rust under your GX 460?
Yes
50.31%
No
49.69%
Voters: 161. You may not vote on this poll
#Rust
Old Apr 17, 2019 | 08:02 AM
  #151
kgbagent1's Avatar
kgbagent1
Check T4R.org 4th gen forums. I personally believe wire wheel, then Rust reformer, then Rustoleum High Performance enamel (brushed on) is the best solution.
Old Apr 17, 2019 | 09:33 AM
  #152
UZ214's Avatar
UZ214
yes I have seen that solution, but for that I need the car lifted; possibly pay someone to do it. I think I can wait couple of years and then get it address or should be taken care of right away?
I will try to post some pics of the spots.
thanks
Old Apr 17, 2019 | 11:18 AM
  #153
kgbagent1's Avatar
kgbagent1
Just park that puppy in the driveway and use a wire wheel on a cordless drill. Wear old clothes and use a drop light. No need for a lift. Not fun but not difficult either.
Old Apr 17, 2019 | 12:30 PM
  #154
ASE's Avatar
ASE
Originally Posted by UZ214
I did my brakes yesterday / just the fronts rotors pads/rotors, I got the car last year and its sitting at 30k miles now, its a 2015. Well when I took the wheels out I realized there were some rust spots that are just forming under the car at some areas.
Anyways I was looking for maybe a spray or something that I can just put on and it does not get worse. Its not at a point where anything needs to be sanded and sprayed over.
Back in the old days I have seen people put used oil in the areas, not sure if that's recommended. I cam across Griot's Garage 11221 Rust Remover Gel ; as an option but wanted to check here on what you guys have done to address it.
thanks!
Look at ACF-50 ... developed by the military for use on aircraft carriers to protect aircraft from (salt-air) corrosion. This product is raved in Europe by the motorcycling community where year-round commuting is common under wet weather conditions ... with motorcycles having many areas that trap moisture, creating spot area corrosion. Comes in a spray can and other containers for applying on large areas. For my use, this is the nuclear version of WD-40 from a surface protection standpoint. Link to product web site ...
https://learchem.com/products/acf-50.html
Here is the company blurb ...
ACF-50 is a state-of-the-art compound for controlling corrosion on aircraft electrical and avionics systems and airframes. ACF-50 kills the corrosion process with just one application and will last for 24 months. ACF-50 is qualified under Mil-C-81309E, and manufactured under ISO 9000 Certified Processes. ACF-50 holds written OEM approvals from: Gulfstream, Bombardier, ATR Regional Transport, Douglas/Boeing Helicopter, Bell/Textron, Robinson, Enstrom, Sikorsky, MD Helicopters, Schweitzer, Hiller, British Aerospace, Concorde Battery, Raytheon, Piper, Cessna, Pilatus, Beech, Van's, Extra, Air Tractor, Lake, Rolls-Royce, Britten-Norman, Learjet, McDonnell Douglas, and Canadair. T
Old Apr 17, 2019 | 12:57 PM
  #155
ShrinkDoc's Avatar
ShrinkDoc
I took my 2014 IS 350 F Sport into Ziebart. They found huge areas of rust and corrosion. After sanding down the rust, they put a coating to protect the car. My point, rust spreads quickly and what is done to protect our cars at the factory has severe limitations. My 04 INFINITI rusted out completely in 13 years, so it's not just Lexus. My neighbor took his Lexus SUV in and is asking for a completely new car due to the severity of the rust in the door panels and beneath the car.
Old Apr 17, 2019 | 02:49 PM
  #156
oubobcat's Avatar
oubobcat
I use fluid film. Get a rattle can and use small amounts. It does a really good job.
Old May 28, 2019 | 10:18 AM
  #157
ObsidianBl's Avatar
ObsidianBl
Default How’s the rust underneath?
On my first oil change outside of the dealer, I noticed some areas underneath starting to rust. I try to do multiple undercarriage cleanings during the winter, but it seems some areas are more prone to rusting. (Underneath where the skids are.) The oil drain bolt was fairly weathered and the oil pan skid started to develop a rust ring all around. The metal wire mesh on the front skid has turned from black to surface rust.
I plan to remove the skids, metal wire brush the rust, pressure wash, then spray some rustoleum rust stopper underneath.
Has as anyone worked with POR15 or Fluid film? I should have done this during the first year before winter....
I’ll try to snap some pictures this weekend, but how’s everyones truck holding up?
Old May 28, 2019 | 10:56 AM
  #158
tigmd99's Avatar
tigmd99
Surface rust is expected on ALL vehicles. You can try to fix it/coat it/etc. But it will return. And you will likely move onto another vehicle before the surface rust becomes significant to affect integrity. My old G-wagen had some surface rust and that frame was dipped in hot wax at the factory!
Old May 28, 2019 | 08:14 PM
  #159
ASE's Avatar
ASE
Look at ACF-50 ... developed for the military for use on aircraft carriers to protect aircraft from (salt-air) corrosion. This product is raved in Europe by the motorcycling community where year-round commuting is common under wet weather conditions ... with motorcycles having many areas that trap moisture, creating localized areas of corrosion. Comes in a spray can and other containers for applying on large areas. For my use, this is the nuclear version of WD-40 from a surface protection standpoint. Link to product web site ...
Old May 29, 2019 | 07:48 AM
  #160
RoadDawg's Avatar
RoadDawg
We live in Portland, OR. We seldom get snow, and when we get it the local authorities publish the routes on which they put salt (NaCL). As far as I know our truck has never been on a salt-infested road. Underneath, I see some slight surface rust on bolts, certain metal parts of bushings, etc. I was pretty surprised when I looked at it, given reports of these trucks being rather badly affected by rust.
I am taking it to the Alvord and Black Rock deserts in a few weeks. It will be interesting to see where and how much fine desert playa dust accumulates on the undercarriage. This stuff is not salty, but I suppose I will be seeking out local car washes or services who might clean the undercarriage after I return.
Old May 29, 2019 | 08:10 AM
  #161
T4Fun's Avatar
T4Fun
no rust at all after 5 years on frame!
minor rust on brakes and stuff around it, but nothing major!
This after 5 years winter in PA
https://www.clublexus.com/forums/gx-...-gx-460-a.html
Old May 29, 2019 | 08:11 AM
  #162
T4Fun's Avatar
T4Fun
still going strong. no rust on frame! Fluid film rocks!
Old Nov 15, 2019 | 04:36 PM
  #163
william489's Avatar
william489
Default Underbody rust
Taken in fall 2018
I have 60k miles on my gx from NE, is this type of rust normal? 2nd photo is taken today and it looks it gets worse quickly for just over a year.
Is this normal for gx from NE? Thanks.
Old Nov 15, 2019 | 05:46 PM
  #164
nuclearn8's Avatar
nuclearn8
That looks better than average for that area and age, congrats!
Old Nov 15, 2019 | 06:01 PM
  #165
tecman's Avatar
tecman
A few more threads around here.
