View Poll Results: Do you see rust under your GX 460?
Voters: 161. You may not vote on this poll
#Rust
spray this all over underneath where there is metal, axle, frame, bolts, springs, struts and you'll be fine. dont get it on the brake discs or pad. you'll need a 12 spray cans.
Amazon.com : Fluid Film 11.75 Oz. Spray Cans. CASE of 12 : Home Pest Repellents : Patio, Lawn & Garden
http://www.oreillyauto.com/site/c/de...id+Film&mc=FFM
saw this product being discussed on Jay Leno's Garage few days ago anyone give it a try?
http://www.por15.com/
sorry if it has been discussed before.
just saw this on the 1st gen GX forum
rust under frames.
GX owners should push lexus to fix this.
http://www.carcomplaints.com/news/20...-lawsuit.shtml
The fluid film is still keeping my GX rust free. Have to put on another coat before the snow comes though
rust under frames.
it will coat and prevent further rust.
It melts off on hot sunny days.
I would wait until late fall or before first snow to apply. Best to apply in 40-50 deg weather
so it forms a thicker layer and wont drip off. Keeps cans indoors and bring them out one at a time and use immediately.
it took me about 8-10 spray cans first time to put thick layer on.
Each year thereafter 6 spray cans.
My 2011 GX spent half of its life in Canada, the other day I was crawling under swapping running board bulbs for LEDs and noticed rust is chewing on heads of the bolts, inner side of break calipers look like someone sprayed them with acid bath. some clamps on hoses in the engine bay look bit rusty, the frame and everything else looks ok...
Wondering if I should replace the bolts and clamps, if so how do I locate those ? Clean it up with wire brush and sand paper then coat it with something ? Or treat them with something like this stuff
. Seems to work pretty good, my only concern with this is chewing into paint
Here is a list of schematic sites if you need to track down some more obscure parts
https://www.clublexus.com/forums/gx-...tic-sites.html
