View Poll Results: Do you see rust under your GX 460?
Yes
50.31%
No
49.69%
Voters: 161. You may not vote on this poll
#Rust
Old Dec 18, 2018 | 10:20 AM
  #106
SigEpGX460's Avatar
SigEpGX460
I've used Fluid Film for years with great results....only takes about a can and a half for me to do the major components once a year.
Fluid Film Link
Old Dec 19, 2018 | 08:35 AM
  #107
konc3pt's Avatar
konc3pt
From: From Oakland to Sactown, the Bay Area & backdown
Fluid Film Link
thanks, gonna give that a try once figure out best way to clean off the rust
Old Dec 19, 2018 | 02:37 PM
  #108
Acrad's Avatar
Acrad
You might want to try one of these wire wheels on a drill and replace what you can't clean up.
If you want take some pics of parts you need to replace and I will help you track them down in schematics.
Old Dec 19, 2018 | 04:43 PM
  #109
konc3pt's Avatar
konc3pt
Thanks Arcad, you are too kind...I got yelled at and was threatened not to mess with the car at the moment, have to wait for pregnancy hormones to stabilize a bit. Those death stares are not pleasant.
Thought about using drill wire brush and still may do it but would probably need to remove the bolts so I don't mess up the paint under there and introduce another problem
Do you think those bolts are torque fastened ?
Old Feb 13, 2019 | 07:37 AM
  #110
AndrewwCal's Avatar
AndrewwCal
Default Krown Rust proofing for the GX?
Hi
Just a thought, do I need to do the rust proofing for my 2017 GX?
last winter I didn't drive the truck but this year I drive it daily and roads in Toronto is infested with salt.
I heard Krown is good but they need to drill holes.
Any GX owner used their service?
Thanks a lot!
Old Feb 13, 2019 | 10:22 AM
  #111
nuclearn8's Avatar
nuclearn8
I have heard good things about Krown, but opted against it for fluid film. I grew up and lived in the Northeast USA rustbelt until two years ago and never had a problem with an annual self-applied coat of fluid film on the undercarriage.
don't hit the brakes, engine, tranny or exhaust with it and you'll be golden. I can wipe, brush and spray on the entire undercarriage in 2 hours max from a gallon container, aerosol cans (I use the frame extension wands as well to get inside the box frame).
undercarriage looks brand new after 10 years. costs about $60-80 a year. kind of a no brainer if you desire to keep a vehicle longterm.
Old Feb 13, 2019 | 07:57 PM
  #112
NTH's Avatar
NTH
I use Fluid Film on the undercarriage of my GX. With 165k miles the under side looks better than most 2-3 year old GXs untreated and left exposed to salt.
Old Feb 14, 2019 | 08:39 AM
  #113
AndrewwCal's Avatar
AndrewwCal
I suppose I can ask autobody shop do this for me?
I am a bit confused here.
Fluid film is different from the oil-method used by Krown?
Old Mar 24, 2019 | 10:54 AM
  #114
ivy's Avatar
ivy
Default GX460 2010 rust under car
Hello everyone,
I'm getting ready to pull the trigger and join the lexus family.
It's a GX460 2011, 110K miles. Great condition outside and in.
And this is how it looks underneath:
I hear various things from different people. E.g that this is normal for NE or this is too much.
BTW, the two bolts that are near the very top of the tailgate and are visible when you lift the rear glass are also corroded. I was wondering how is this possible, since there are no ways that water can reach that part.
What should I tell to the dealer? Is there something they can do about it? Should I worry?
Forget this truck?
Thank you!
Old Mar 24, 2019 | 12:01 PM
  #115
Acrad's Avatar
Acrad
I'd personally pass but that is just me. That being said I have seen far worse and most of this would probably be not to hard to clean up. The skid plate is removable and replaceable so I wouldn't even factor that part in. I'm no rust expert by any means so will leave that for others to comment. My '12 came out of southern California so it was really rust free.
Old Mar 24, 2019 | 12:08 PM
  #116
tecman's Avatar
tecman
The rear bolts are outside of the weather strip so they do get wet. Some links to look over if you have not seen them.
https://www.clublexus.com/forums/gx-...x-460-a-5.html
https://www.clublexus.com/forums/gx-...nge-bolts.html
Old Mar 24, 2019 | 12:58 PM
  #117
ivy's Avatar
ivy
Thanks. I like how the car looks inside & out, so my number one goal is to understand whether it might put me into trouble down the road. I'm originally from a rust free region, so my only experience until now, was rust (even a little bit) = avoid. However, here in the NE it's a fact of life. I can't estimate though where the line is.
Old Mar 24, 2019 | 01:00 PM
  #118
ivy's Avatar
ivy
Originally Posted by tecman
The rear bolts are outside of the weather strip so they do get wet. Some links to look over if you have not seen them.l
Thanks tecman. They're really useful. Do you believe I could ask the dealer to change the hinges or do something about it (as well as for the rust underneath)?
Old Mar 24, 2019 | 01:17 PM
  #119
tecman's Avatar
tecman
Guess it depends on the dealer and profit margin. Being that you are looking for an older GX I would think there are better options out there without this concern.
Old Mar 24, 2019 | 03:44 PM
  #120
hzhao's Avatar
hzhao
25 Year Member
Not an expert on the rust subject. But judging from PM's signature, assumed the GX is from the Northeast region (up New England area), with the harsh winters for all those years, that looks just about right to me.
