Smart Access Disabled? - Key Fob Programming Error
Old Jan 23, 2024 | 05:30 PM
Woollybugger802's Avatar
Woollybugger802
9th Gear
Default Smart Access Disabled? - Key Fob Programming Error
Hi guys,
New member here with a ‘21 GX, hoping someone can help me out.
I had one key fob that worked perfectly and ordered an 2nd oem from a dealer. Used Techstream to program the new fob, however, at the last step an error occurred and I’ve seemed to lost/deactivated my smart access. Both fobs are registered and will start the car. Neither fob (nor door handle sensor) will lock or unlock the car. Unfortunately the error message disappeared quickly.
Is this destined for the dealer to fix or is there a setting in Techstream I can enable?
thanks in advance!
Old Jan 23, 2024 | 06:37 PM
hzhao's Avatar
hzhao
25 Year Member
Have you checked under Settings, if Smart Access has been disabled?
Old Jan 24, 2024 | 06:36 AM
Woollybugger802
9th Gear
Thanks for the reply! In the Enform settings? No everything looks good there. I’m not a Techstream expert but all of the Smart Access settings look correct there as well. It seems to logging the lock/unlock requests, it’s just not fulfilling the request.
Old Jan 24, 2024 | 06:51 AM
hzhao's Avatar
hzhao
25 Year Member
Just the OEM on screen setting, under car’s customization section, there is an option to turn Smart Access on or off…. (2021 GX Manual Page 587)
Old Jan 24, 2024 | 07:52 AM
Woollybugger802
9th Gear
I can’t actually find that setting in the menu, I’ve read toggling that is a dealer setting. That said, the push button starts fine, so if that were off I think I’d need to do the process of holding the key to the push button.
Old Jan 24, 2024 | 11:04 AM
Acrad's Avatar
Acrad
IIRC... it is further down on this screen but watch video how to get here
Old Jan 24, 2024 | 11:38 AM
Woollybugger802
9th Gear
Originally Posted by Acrad
53:18
https://www.youtube.com/watch?v=2CaJjBSqrPc&t=3198s
thanks these are the options I have in that menu:
Old Jan 24, 2024 | 11:53 AM
Acrad's Avatar
Acrad
Interesting as they do show option there for 2021 in the LPS document for 2021 at #7 but 2022+ (#16) they made it dealer only
https://lexusgxor.com/_media/general:22_gx_lps_cst.pdf
https://lexusgxor.com/_media/general...r_lps_form.pdf
https://www.clublexus.com/forums/gx-...tings-lps.html
Old Jan 24, 2024 | 12:09 PM
Woollybugger802
9th Gear
Interesting indeed! Thanks for the resources. Lexus is about 2 hours away, so I have an appt with Toyota for tomorrow. Will report back with what I learn.
Old Jan 25, 2024 | 12:58 PM
Woollybugger802
9th Gear
Toyota was able to fix by reprogramming both keys. What still doesn’t make sense (to me) is why my original key programming was screwed up by programing a new key.
Anyway, just wanted to share the resolution in case it helps someone in the future. Thanks for the replies!
Old Jan 25, 2024 | 02:34 PM
hzhao's Avatar
hzhao
25 Year Member
Glad you got it resolved. It is possible the version of your techstream might be outdated which may not fully support 22+ GX that resulted only partially programmed key due to newer versions of ECUs.
Reggie1
RZ Model (2023-present)
Dec 11, 2023 11:51 AM
Billst
NX - 2nd Gen (2022-current)
38
Sep 30, 2023 11:41 AM
PaulaB
Apr 15, 2021 08:32 PM
alex22
CT 200h Model (2011-2017)
22
Apr 16, 2019 11:08 AM
silkx3
Dec 4, 2016 02:35 PM
