Toyota SLL Coolant
Toyota SLL Coolant
I just wanted to double check and make sure that the correct coolant to use for our cars is the Toyota Super Long Life Coolant (SLLC). I'm at around 130,000 miles and the car is five years old, and I'm hitting the "low" mark for the coolant. Am I ok with just topping the coolant off or do I need to drain the radiator and replace the coolant? TIA
Tech Info Resource
You probably need to get your valley plate leak repaired.
Yes, the pink stuff, SLLC is what these engines run from the factory.
