alignment expectation question
Old Jan 19, 2011 | 08:26 PM
schan1w's Avatar
schan1w
Default alignment expectation question
When my GX was new, it would go down the highway, tracking straight and stable. How after 55K miles, it pulls to the right. Got new tires, and had a alignment done at a Toyota dealer. Got everything in spec, but still pulls to the right, not much difference after the alignment. Should I expect straight tracking? Everything is suppose to be in spec now, but not sure why it's not tracking straight. Any info would be appreciated. Thanks!
Old Jan 20, 2011 | 10:11 AM
ca5280's Avatar
ca5280
10th Gear
Do this:
Park on a flat/level surface, measure the height to the fender on each corner, compare the R to L, you might be aligned correctly, but maybe the suspension is off.
Hope this helps.
Old Jan 20, 2011 | 03:40 PM
Troy L's Avatar
Troy L
This is not to suggest that you are not dealing with a reputable service center, but I am a bit suspicious. In addition to what has already been stated as a possibility, I believe you should try one additional step. Go to a differerent alignment facility, and ask for a before and after alignment printout. It could have been that no alignment was actually done, or it was done improperly. The before/after documents give a bit more assurance of a difinitive problem, and the actual action taken to correct an out-of-alignment condition. Unless the vehicle has been involved in a relatively serious front-end crash, it should still track like new. I had a similar experience a few years ago, and later found out that the alignment equipment had been improperly calibrated. All recent alignment customers had to be called back in for adjustments, after the equipment maker made the necessary corrections. The GX is possibly the finest vehicle on the road, and, with the mileage you report, there is no justification for "pulling," if the alignment is to factory spec. Good luck...
Old Jan 20, 2011 | 03:53 PM
schan1w's Avatar
schan1w
When new, I can go 10 seconds or more on a straight segment of highway at 65mph hands off the wheel and it tracks perfectly straight in my lane. Now, I go about 4-5 seconds before I almost leave my lane and have to put my hands back on the wheel. Before the alignment, it was about 3 second. So it's slightly better, but definitely not like new.
Old Jan 20, 2011 | 08:12 PM
ROSCOGX470's Avatar
ROSCOGX470
Just curious, After your alignment did you need or replace your tires. If you had alignment issues you may have worn the tires in a manner that would promote drifting. Worth a quick look.
Old Jan 20, 2011 | 09:25 PM
schan1w's Avatar
schan1w
Got new tires, then did the alignment.
Old Jan 21, 2011 | 10:04 AM
mann777's Avatar
mann777
I had the same problem after I replaced my tires, gave it back to the dealer and, Following was done.
1. First they swapped the Front tires and checked and still there was a slight pull to the right.
2, Next they increased the Front Left Camber and decreased the Right Front Camber, until the pull was completely elimanated, The truck was left for a day as they had to a series of Test drives. And here they made sure the Cross Camber was left left within 1( degree).
Maybe you can quote to the dealer to do this. Hope this helps.
Old Jan 22, 2011 | 08:23 AM
HaveBlue's Avatar
HaveBlue
If the camber is ok then they can add some caster to the right to eliminate the pull too. It's worth rotating the tires to verify that there isn't a defect there.
RON7
RX - 4th Gen (2016-2022)
Jan 13, 2016 02:04 PM
MrG4Life
Suspension and Brakes
47
May 26, 2013 07:26 AM
Legender
May 24, 2013 03:39 PM
MI350_55
Oct 28, 2009 02:09 PM
kjbro
Jul 22, 2004 03:35 PM
