Front Plate Bracket? or Screw?
Old Nov 20, 2008 | 08:48 PM
hoonami's Avatar
hoonami
Default Front Plate Bracket? or Screw?
I was wondering if there is a bracket that holds front plate or do we just use plate screws only? and is there certain size screws I use or do i just grab standard plate screw in box from autozone? I hate to drill a hole but Illinois law got strict with front plates. Thanks Guys!!!
Old Nov 21, 2008 | 10:59 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
There is a bracket that bolts onto the front bumper.
I do not have a front plate and when my boy needed the GX for his drivers test I fab'd a L-bracket from under the bumper that went up in front of the bumper that I attached the plate to in order to pass the vehicles inspection (California is **** that way). Worked fine and he passed.
Old Nov 21, 2008 | 11:52 PM
malmon's Avatar
malmon
The GX I got has two predrilled holes with screws on the front bumper, not sure if its from the factory or the dealer, no brackets.
Old Nov 22, 2008 | 08:49 AM
hoonami's Avatar
hoonami
Thanks Guys, Most GX's i've seen on the streets didn't have brackets, plates were just held with 2 screws only...
Old Nov 22, 2008 | 07:11 PM
itsZep's Avatar
itsZep
i always thought that was odd myself....
i guess they dont use front plates in Japan?
Old Nov 22, 2008 | 09:13 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Problem with attaching the plate directly to the bumper would be paint wear from the edge of the plate unless one uses a spacer (washer) between the two.
Old Nov 24, 2008 | 04:11 PM
BobsGX's Avatar
BobsGX
From the factory, the GX does not use a mounting bracket to hold the front license plate. The license plate (and plate frame if you use one) are just attached to the front fascia with 2 screws. If you look closely at the front fascia, you will see 2 dimples where the 2 screws get attached.
Old Dec 11, 2008 | 02:01 PM
jquinn14's Avatar
jquinn14
alright, here's a dumb question...I have removed the front license plate and two screws...now I have two holes. What should I use to fill them? I tried looking for hole inserts that are white, but haven't had any luck. I am sure there is something simple but I couldn't find anything at Home Depot...thx in advance for any suggestions.
P.S. this needs to be a temporary solution as I live in CA and may need to reattach the plate to clear a fix-it ticket should I ever receive one...;-)
Old Dec 11, 2008 | 07:27 PM
Capirato's Avatar
Capirato
Go with:
http://www.bumperplugs.com/
~ Cap
Old Dec 12, 2008 | 01:53 PM
jquinn14's Avatar
jquinn14
Great suggestion - thank you! I would never have found these. I just ordered them and can't wait to install. Now, if it was only that easy to find someone to put the ipod adapter in my car for a reasonable price! ;-)
Thanks again!
Old Dec 28, 2008 | 12:34 AM
Capirato's Avatar
Capirato
Thanks again!
Julie.....
How did the Bumper Plugs work out ??
~ Cap
k20trick
IS F (2008-2014)
16
Dec 9, 2015 06:56 AM
Brandnewme
Mar 16, 2015 06:43 AM
99suprduty
GX - 1st Gen (2003-2009)
Sep 1, 2013 07:14 PM
memphisto
Nov 30, 2012 03:43 AM
vwong
Oct 10, 2005 05:29 PM
