AC servo Replacement
Old Nov 17, 2021 | 01:40 PM
mdanfas's Avatar
mdanfas
Default AC servo Replacement
My 2016 GS350 got hit the the infamous AC servo issue. I have the B1441 code in AC ECU.
Is it an easy DIY replace or does it really need professional help?
couldn't find a write up considering this is common problem with these cars.
Thanks in advance.
Old Nov 17, 2021 | 01:59 PM
jsch222's Avatar
jsch222
Search is your friend:
https://www.clublexus.com/forums/gs-...ll-notice.html
It's quite a task. Is your servo covered under the recall?
Old Nov 17, 2021 | 02:58 PM
AJLex19's Avatar
AJLex19
@mdanfas Lexus USA has a program to fix an AC Servo motor issue. It looks like you are in the UAE - contact your local Lexus dealer and maybe show them the following taken from the Lexus US support program and see what they say...:
Old Nov 19, 2021 | 01:06 PM
veez81's Avatar
veez81
my 2015 has this and im bringing it in tuesday to get fixed. check your vin number online to see if your car qualifies
Old Nov 19, 2021 | 09:12 PM
Neophyte2b's Avatar
Neophyte2b
Where do you check it online?
Old Nov 23, 2021 | 03:03 PM
veez81's Avatar
veez81
the letter i received from lexus directed me to this webpage to see if it qualifies:
https://www.toyota.com/recall/update-info-lexus
when i started getting the issue, i called my dealership and they already had it on file for me. call your local lexus and give them you VIN and they should be able to help you out if the webpage doesnt work properly (it seemed buggy when i entered my info)
Old Nov 26, 2021 | 02:08 PM
mdanfas's Avatar
mdanfas
Default Temporary solution
I had a Mini VCI cable with me. So got the latest Techstream version and the issue is solved for now by initializing the servos.
I live in UAE and the recall is not valid here. So I'll be using it till initialization will never fix it.
Thanks everyone for the replies 🙌🏼😃
Old Nov 29, 2021 | 05:47 AM
aachowhan's Avatar
aachowhan
I wish I could get techstream working. I tried and it didn't work for me.
Old Dec 6, 2021 | 01:44 AM
mdanfas's Avatar
mdanfas
Default Techstream
I don't know if it's allowed to post about techstream cracked versions here. If you have the cable, DM me in insta @ mdanfas I'll send you the files needed for it to work in win10
S197mike
RX - 1st Gen (1999-2003)
Apr 11, 2021 09:18 PM
HrdPrkDGS4
Aug 31, 2012 08:04 PM
yamiken1
GS - 1st Gen (1993-1997)
Jul 8, 2012 11:08 PM
isiginamo
Apr 21, 2008 05:12 PM
2JZPOWER
Sep 14, 2007 03:32 PM
