Need ac help
Old Jun 20, 2012 | 04:08 PM
yamiken1's Avatar
yamiken1
Default Need ac help
My 1994 gs300 ac been giving me intermittent problems. The compressor clutch keeps kicking on and off rapidly intermittently. I can feel it jerking when I drive. The compressor has been replaced and recharged to correct specs. But the problem still exist. Becuase it's intermittent I am unable to dg what is wrong. Has anyone ran into a problem like this? Ecu has been checked by a company that rebuilds them. Nothing wrong with ac circuit. So I was told. Any suggestion? High press switch going bad? Ac amplifier? Ac control unit? Thanks!
Old Jun 20, 2012 | 04:10 PM
yamiken1's Avatar
yamiken1
Forgot to add, the ac starts to blow warm sometimes when ac clicking on and off. Sometimes it will click back on and stay on. Other times it won't till I shut it off then turn it on later.
Old Jun 20, 2012 | 04:23 PM
2GSC300's Avatar
2GSC300
My suggestion would be to put the gauges on it and check for leaks in the system.
Old Jun 20, 2012 | 06:22 PM
yamiken1's Avatar
yamiken1
I put gauges on it and pressures normal. When I changed the compressor and drier I evacuated the system and it held 30" for 30-40 mins. Then filled in freon. So no leaks.
Old Jun 23, 2012 | 05:42 AM
2GSC300's Avatar
2GSC300
Check your relays. I have to change my condesor/rad fan relay today. My AC is blowing hot/cold. You may have a compressor relay or fan relay going out.
Old Jun 23, 2012 | 01:59 PM
slammd_gs3's Avatar
slammd_gs3
U maybe having a problem with the control head. Sometimes my ac switch blinks and compressor turns off under acceleration.
Old Jun 24, 2012 | 03:00 AM
yamiken1's Avatar
yamiken1
2gsc300-Ok. Will try replacing relays. But I swapped the ac magnetic clutch relay with the ign one since its the same part number. No difference.
Slammd_gs3- I used to have a blinking ac light when the ac would shut off. Now it shuts on/off but ac light stays on. I wonder if it is the ac control unit going bad. Did that fix your problem?
Thanks for all your input. It is greatly appreciated!!
Old Jul 8, 2012 | 11:08 PM
resen323's Avatar
resen323
I have the same problem, I kept melting the magnetic clutch. Happened 3 times. I found out that the high side gets to high. Our compressors shut off at 450 psi, I'm gonna replace my condenser fan with a stronger one. That should take care of it..
joey671
Jul 11, 2017 07:40 PM
gvcenter54
RX - 1st Gen (1999-2003)
12
Jul 28, 2014 04:10 AM
hazepurple
Nov 27, 2011 07:48 PM
2JZPOWER
Sep 14, 2007 03:32 PM
dj.ctwatt
Mar 10, 2004 12:32 PM
