Steering issues
Old Sep 19, 2021 | 01:00 PM
Jayhova's Avatar
Jayhova
Default Steering issues
Good Day to all,
I been having this issue with my steering to the point that dont even remember if its something that normal on my 2015 gs350 fsport. I upload a short clip. But basically, if there is the slightest imperfection on the road and i brake at a slow speed the steering wheel turns on it own and it wont recover. Everything thing on this vehicle is oem. No changes or mods.
File Type: mov
Old Sep 21, 2021 | 01:43 PM
bearcav's Avatar
bearcav
Seems like the brake caliper on the passenger side is sticking if it only happens when braking. Caliper sticks and brakes only front passenger wheel, pulling the car that way. You could also have other worn out suspension components and/or too much toe/toe-out in your alignment that makes the problem worse because the car doesn't re-center.
Old Sep 21, 2021 | 05:24 PM
jgscott's Avatar
jgscott
Sounds like the known Lexus steering rack issue, that many Lexus and Toyota's have suffered from.
Old Oct 4, 2021 | 08:54 AM
Kam7001's Avatar
Kam7001
Originally Posted by Jayhova
Good Day to all,
I have this exact issue. Usually braking at a slightly bumpy road will guarantee this.
Old Oct 4, 2021 | 07:21 PM
GSJ350's Avatar
GSJ350
I have a 15 base model and i have similar issues as well. Seems like either the electric power steering and or the articulation of the suspension is different than any other car ive owned. One thing i have noticed especially, is the crown of the road at above 60+ has a huge impact on the vehicles tracking going straight. Below 60 its perfectly fine and not so much of an issue unless the road is grooved then it does what is described by others above.
Old Oct 4, 2021 | 08:06 PM
Kam7001's Avatar
Kam7001
This seems different from my vehicle. On my vehicle, issues only occur at low speeds and breaking gently on a slightly bumpy road. The steering just gives up all control as if the electronics are turned off.
Old Oct 5, 2021 | 07:15 AM
Knucklebus's Avatar
Knucklebus
The easiest thing to do is check the brake caliper for smooth motion. If it is dragging, it will show more wear than the other wheel side. It might even show more wear on the inside/outside of the same caliper if it is sticking in one place.
Once you rule that out, you can move on to the more difficult and expensive options.
Old Oct 5, 2021 | 07:17 AM
Kam7001's Avatar
Kam7001
I'm actually looking to get mine replaced soon as well. Any suggestions on brands? First time replacing pads lol.
Sondoan
NX - 1st Gen (2015-2021)
Nov 7, 2016 10:35 PM
stuch
Mar 10, 2016 02:27 AM
munozj
Dec 29, 2013 05:19 PM
airforce12
Aug 12, 2012 10:47 PM
