Dashcam setup
Old Jun 9, 2021 | 10:27 AM
websurfer's Avatar
websurfer
Default Dashcam setup
Hi All,
I'm thinking about installing a dashcam in the GS, can anyone share how they setup?
I watched a bunch of Youtube videos but not on the GS though. Thanks.
Old Jun 9, 2021 | 10:35 AM
byungkuk's Avatar
byungkuk
Used the rain sensor adapter plug and put the camera left of the center stack - i put it just high enough to cover the camera itself with the black dots - only the lens is below them...
Helped my friend install his using the same method in less than 30 mins on his RX (but right side)
Old Jun 9, 2021 | 11:17 AM
websurfer's Avatar
websurfer
I saw you have posted that url to the item but it sold out. I found a similar one on Amazon.
https://smile.amazon.com/dp/B08PC7N9...v_ov_lig_dp_it not sure if you tried this manufacturer also?
Thanks.
Old Jun 9, 2021 | 11:38 AM
HontoKuro's Avatar
HontoKuro
May want to go here..... https://www.clublexus.com/forums/gs-...am-for-gs.html
Old Jun 9, 2021 | 12:00 PM
byungkuk's Avatar
byungkuk
Thanks.
that's the exact one 10-pin Type B...
FWIW I tried the other type (SimpleUSBCable) where you plug in the red and black wires into the rain sensor but they kept popping out
Old Jun 9, 2021 | 01:39 PM
websurfer's Avatar
websurfer
Thanks, I'll wait to test out the Viofo before I purchase. It's $30 for a cable is pretty $$$ though.
Old Jun 9, 2021 | 01:40 PM
byungkuk's Avatar
byungkuk
definitely cheaper to tap a fuse by pulling the cable through the a pillar and headliner but i'm too lazy for that lol
Old Jun 9, 2021 | 07:05 PM
websurfer's Avatar
websurfer
I've been watching videos on fuse tap. Load side is important
I rather use that connector now, any way to take a picture how it looks?
Old Jun 9, 2021 | 07:26 PM
byungkuk's Avatar
byungkuk
https://www.clublexus.com/forums/gs-...clean-way.html
if you look at the picture in this thread one of the pictures shows the black rain sensor(?) plug.. you simply use the adapter to piggy back off of that plug to power the dashcam.. when you pop out the center stack cover you will see that one end had a circular opening... simply pull the cord out through there to connect to your dashcam.. I think my friend used a 90 degree mini usb plug to power his dashcam (not necessary)
Old Jun 9, 2021 | 07:43 PM
websurfer's Avatar
websurfer
Thank you for the info
Old Jun 9, 2021 | 09:28 PM
websurfer's Avatar
websurfer
Google a bit more. Same company but different name.
https://www.facebook.com/dongartech/
More pictures also. Awesome product, just purchased one 1. I didn't feel like fuse tapping also
Did yours come with some usb cables also?
Old Jun 10, 2021 | 07:27 AM
byungkuk's Avatar
byungkuk
Yes it came with mini and micro usb cables which is convenient
Old Jun 10, 2021 | 10:47 AM
bumada's Avatar
bumada
https://www.clublexus.com/forums/gs-...hardwired.html
This is the DIY I wrote for the GS
Old Jun 10, 2021 | 02:25 PM
ItzFilyO's Avatar
ItzFilyO
I have the old Thinkware F750 dash cam that has been going strong for almost 10 years, 24/7 in the car in all weather. I just transferred it whenever I traded in my cars.
I ran my cable through the headliner and pillar, under the front passenger seat, all the way to the center console cigarette plug because I don't like to mess with the factory wiring and it's a clean install.
Old Dec 26, 2021 | 03:19 PM
websurfer's Avatar
websurfer
Sharing a video on how to setup to help others that are interested.
metalgear
Sep 8, 2009 11:36 AM
Emontes7
Jan 22, 2009 03:24 PM
j0xxx
Feb 24, 2008 09:24 PM
LexFather
Sep 11, 2006 10:03 PM
gswatkins
Mar 6, 2001 08:47 PM
