Codes set C1241, B1927, B1856
Old May 17, 2021 | 06:08 PM
kptownsend's Avatar
kptownsend
Exclamation Codes set C1241, B1927, B1856
Hi Folks,
My 2015 F-Sport set these codes recently. C1241 ABS code... low battery positive voltage; B1856 Airbag code... climate control air temp internal sensor; B1927... passenger side airbag.
None are critical but I would like to get them cleared or repaired. I recently replaced the car battery (they were on before that). Any suggestions or experience with these? THANKS!
Old May 17, 2021 | 08:27 PM
byungkuk's Avatar
byungkuk
i assume you can do that with techstream since nothing is really wrong
Old May 17, 2021 | 11:09 PM
703's Avatar
703
Those codes are set using trip detection logic. So I wouldn’t assume it’s nothing. Unless you know exactly what you did to trip it.
Old May 18, 2021 | 05:26 AM
kptownsend's Avatar
kptownsend
what is techstream?
Old May 18, 2021 | 06:56 AM
MX73's Avatar
MX73
Originally Posted by kptownsend
what is techstream?
Toyota/Lexus diagnosis scanner. A fancy OBD II reader that you can customize and look at key system stats in greater detail.
Old May 18, 2021 | 07:26 AM
Cwang's Avatar
Cwang
They're historical, just clear them.
Old May 18, 2021 | 11:38 AM
703's Avatar
703
Sounds current to me.
Old May 18, 2021 | 04:31 PM
Cwang's Avatar
Cwang
How do you know? They were on before the battery was changed, they're just the codes you'd get with a failing battery, chances are they just need clearing.
If those codes are current then the OP has one messed up car,or the new battery is bad.
Bp350
Nov 6, 2020 12:04 PM
Homesirius
Sep 14, 2020 06:06 PM
shanklejim
RC F (2015-present)
Aug 29, 2019 06:44 AM
oraneivey
Jan 12, 2017 12:02 PM
