Engine code confusion
Old Aug 27, 2019 | 05:46 PM
shanklejim's Avatar
shanklejim
Default Engine code confusion
Started my 2015 RC F yesterday morning and the SRS light came on and my climate control is running but can't be turned on or off. I took the car to a local shop and the following codes showed up but couldn't be cleared or corrected.
B14B2 - Lost communication with front panel LIN
U0613 - Lost communication with Nav control module
B1660 - Passenger airbag on/off indicator malfunction
B14B5 - Lost communication with front seat temp adjustment switch
any ideas what could be the cause or how to correct. I live no where close to a Lexus dealership.
Old Aug 27, 2019 | 09:34 PM
buister's Avatar
buister
Have you tried the simple reboot trick, which is disconnecting and reconnecting the battery's negative terminal, to see if the computer would reset itself?
Old Aug 28, 2019 | 06:13 AM
GunnyFitz's Avatar
GunnyFitz
Thumbs up Ditto
Hey, that works with everything else in this world, may as well give it a try for sure! I Can honestly say, I've never seen a Trouble Code on this car, nor do I know where it shows up either!
Old Aug 28, 2019 | 07:49 AM
shanklejim's Avatar
shanklejim
I haven't tried disconnecting the battery yet. I will do that tom when I get home from the Firehouse and let you know. Thanks for the advice
Old Aug 28, 2019 | 09:59 AM
Pittsy's Avatar
Pittsy
Try not to create multiple threads on the same issue https://www.clublexus.com/forums/rc-...nctioning.html
However, disconnect the battery for 30-45 minutes and let everything reset. If the codes still persist, bring it to Lexus. You really dont want to mess around with the SRS.
Old Aug 28, 2019 | 04:34 PM
shanklejim's Avatar
shanklejim
Thank you for the info and I'm sorry for the duplication of threads. I won't do that again. Does it matter if I disconnect the Neg side or the Pos side of the battery? I've seen people say it both ways.
Old Aug 29, 2019 | 06:44 AM
OldManRCF's Avatar
OldManRCF
it works both ways, buts it's "safer" to remove the negative cable. to speed the process up, after disconnecting the battery, hold down the brake until the light goes out. reconnect battery
jonathan58
Feb 24, 2019 12:15 PM
AL13NV8D3R
Nov 20, 2018 10:43 PM
slun
Dec 17, 2017 06:42 PM
roachman
May 23, 2011 07:03 PM
BklynRX7
GS - 1st Gen (1993-1997)
Oct 20, 2008 09:51 AM
