Check SRS airbag system
Old Nov 6, 2020 | 01:38 AM
Bp350's Avatar
Bp350
Default Check SRS airbag system
Got a nice little caution light with a pop up showing check srs airbag this morning on my way to work in my 2014 is350. Any idea of how I can get rid of this code?
Old Nov 6, 2020 | 05:10 AM
Sasnuke's Avatar
Sasnuke
It really depends what the code is. Usually airbag codes need to be cleared with a scan tool...but having said that they usually only come on when there is significant problem that requires repair.
You could try disconnecting the battery for 10 minutes (at least), but I doubt it will clear the code.
Any chance you have something to read the code?
if not, might I suggest this:
Amazon Amazon
It's $23 on Amazon and you can download several free apps to work with it...like Carscanner.
I've used it on my Highlander and it checks for codes in all the systems, and you can clear the codes too.
Old Nov 6, 2020 | 12:04 PM
s3v3n's Avatar
s3v3n
Could be a sensor but it may also related to your seatbelt. It may also be a fuse. Light may come back after clearing it.
I'm almost positive there was a recall on this somewhere so if it comes back after clearing it, after ECU reset and after checking all the fuses, I'd go to Lexus SC and have them check but hopefully it won't go that far.
JSSinoda
GX - 1st Gen (2003-2009)
May 8, 2018 06:26 AM
REMON2020
Sep 24, 2017 07:45 AM
teddypainz
Dec 29, 2011 09:42 PM
TMaxxTim
May 16, 2005 08:48 PM
