2013 ->2016 Headlight Conversion
Old Mar 12, 2026 | 05:54 PM
centraxge's Avatar
centraxge
10th Gear
Default 2013 ->2016 Headlight Conversion
Hi all! I recently purchased the Alibaba 2016 triple beam headlights with the 2013 plug. I got around to test fitting them today and came up with a few issues. 1. The DRL's don't turn on at all, I read this is a common issue with the aftermarkets but no one really explains how to fix it. 2. The driver side light hyper flashes but the passenger does not, I am afraid if I try to use a load resistor, it will damage the lights as they have a shared ground. 3. The car throws a Headlight Leveling System Malfunction code which is due to the fact that these lights do not have auto leveling or AFS. I am pretty positive you disconnect a AFS plug behind the dash to remove the error code. Any help would be much appreciated!
Old Mar 12, 2026 | 06:44 PM
jgscott's Avatar
jgscott
From what I have seen over the last few years about those lights on FB and here. Some work out the box some don't. Some modify them for a problem like you have or send them back for a replacement set that work.
Then the next post (tick, tick, tick) is that 1 or 2 of the Headlight LED's quit working after a few months. Is why I installed the 450h Triple beams in my 13 GS350 instead.
This thread may help except for no Daylights.
https://www.clublexus.com/forums/gs-...headlight.html
Old Mar 13, 2026 | 12:12 PM
Richb1954's Avatar
Richb1954
What year 450h headlights did you use. How was the install? I have a 2014 Lux and was considering that option
Old Mar 13, 2026 | 03:16 PM
jgscott's Avatar
jgscott
Got then from ebay. They were 13-15 450h Triple Beams. Install was plug and play. Required front Bumper removal. I did while also doing a ebay GS F front bumper swap also.
deptrai89
GX - 2nd Gen (2010-2023)
Jan 31, 2026 01:56 AM
bryan11
Apr 20, 2024 07:05 PM
rxtarcher
CT 200h Model (2011-2017)
Dec 2, 2023 08:01 PM
natieboo
GS F (2016-present)
Oct 26, 2022 12:40 AM
bennyc
Oct 6, 2010 11:26 PM
