PCV Valve 2016+
Old Jul 8, 2023 | 12:43 PM
TLE86's Avatar
TLE86
Default PCV Valve 2016+
Has anyone replaced a PCV valve on a 2016 + 350? I saw the DIY for the pre 2016 years but I wasn't able to locate it on my 2017. It's definitely a different layout where the PCV valve should be.
If anyone has a picture of where it's located, that would help, thanks!
Old Jul 9, 2023 | 05:54 AM
Peaches2016's Avatar
Peaches2016
10th Gear
If you're standing in front of the engine then the PCV valve is located on the right side of the engine near the firewall. It's on the very back of the engine and has a rubber hose going into it. Lexus used a pinkish color thread locker on the PCV that should be partially visible and should help you locate it.
Old Jul 9, 2023 | 06:54 AM
warmdye's Avatar
warmdye
I changed my pcv valve yesterday related to a P0101 code I'm troubleshooting . I was wondering what that pink/purple plastic piece was for. The new one didn't have this piece so I just swapped it over to the new one. I didn't notice any sealant on the old pcv valve threads so I didn't put any on the new one. The original pcv valve had 130k miles on it and seemed to still work fine with minimal buildup.
Old Jul 9, 2023 | 11:57 AM
gs350noob's Avatar
gs350noob
I have a 2013 and I ordered a valve for mine too. I figured it was $8 so what the heck I'd do it when I get around to doing the spark plugs. It looks a little tricky to get to as it's buried in a corner a bit. Mine didn't come with the little purple deal either.
Old Jul 9, 2023 | 12:43 PM
EdgarLex's Avatar
EdgarLex
Originally Posted by TLE86
Has anyone replaced a PCV valve on a 2016 + 350? I saw the DIY for the earlier years but I wasn't able to locate it on my 2017. If anyone has a picture of where it's located, that would help, thanks!
I think the refresh Atkinson GS’s don’t have a PCV valve.
Disregard what I said. See my post down below for more information.
Old Jul 9, 2023 | 05:51 PM
jgscott's Avatar
jgscott
Well this will be interesting.
Old Jul 9, 2023 | 06:07 PM
TLE86's Avatar
TLE86
Say what? If that's true, saves me the time to change it lol
Old Jul 9, 2023 | 06:19 PM
TLE86's Avatar
TLE86
Love your youtube videos BTW!
Old Jul 9, 2023 | 06:41 PM
EdgarLex's Avatar
EdgarLex
TLE86, first of all I want to apologize for the misinformation, guess I was remembering things wrong when thinking about the vacuum pump and brake booster on the FKS. I was at a eyebrow salon on my phone when I sent the first reply lol.
This car does have a PCV valve. I believe it is under a foam portion underneath next to the brake reservoir. Check out this thread on Tacoma world which also uses the 2GR-FKS. Doesn't look as easy as the old 2GR-FSE
https://www.tacomaworld.com/threads/...t-help.771466/
Returd
Jun 2, 2023 07:47 AM
decypher
Aug 22, 2011 09:30 PM
