PCV value Replacement
Old Apr 20, 2023 | 04:10 PM
Sal2030's Avatar
Sal2030
9th Gear
Question PCV value Replacement
Is there a schedule (mileage or years) to replace the PCV value? has anyone replaced one on 2016 or newer?
Old Apr 21, 2023 | 09:43 AM
MX73's Avatar
MX73
No schedule for PCV. I usually replace it every other oil change or when I change out my spark plugs. It's like a $10-$15 part.
Old Apr 21, 2023 | 01:38 PM
Sal2030's Avatar
Sal2030
9th Gear
Do you need to remove the plastic intake manifold to replace the value?
Old Apr 21, 2023 | 01:42 PM
MX73's Avatar
MX73
No, you don't need to remove the intake manifold. The video is from an IS but it's the same engine and layout. You'll need a 19mm wrench to get it loose.
Old Apr 21, 2023 | 01:47 PM
Sal2030's Avatar
Sal2030
9th Gear
Thank you MX73 for the quick response.
Old Apr 22, 2023 | 10:11 AM
Mangsailor's Avatar
Mangsailor
Veteran: Navy
How often do you change your oil, and what is your logic behind changing it preventatively as you do?
Old Apr 22, 2023 | 11:20 AM
MX73's Avatar
MX73
Back then when the GS is my daily, every 10k. As I've stated, It's a cheap $10 part that can prevent hundreds of dollars down the road. And only requires a minute of my time.
Old Apr 6, 2025 | 05:34 PM
andryakaad's Avatar
andryakaad
10th Gear
I've just created a small tutorial in a proper category since I couldn't find any info abou nx300's PCV valve either - https://www.clublexus.com/forums/nx-...l#post11892035 .
Old Apr 6, 2025 | 05:41 PM
MX73's Avatar
MX73
Applies to the GS200t/300 4 cyl. If anyone is questioning this...
Old Apr 6, 2025 | 10:37 PM
dzejdzej007's Avatar
dzejdzej007
Old Feb 23, 2026 | 01:06 PM
ArgonBlue's Avatar
ArgonBlue
Just finished up the replacement of mine on a 2014, I think things are slightly different on the newer gs models (not 100% sure though)
My install was super easy, mainly due to using a 19mm crows foot wrench. It’s perfect for the job since you can’t get a socket on there and wrenches would take forever. Also, with a crows foot, you’re able to torque it down. Maybe it’s not 1000% accurate but it’s still works for me. 3/4 inch crows foot also works (19.05 mm)
I did notice that there was a little bit of gray material on the threads of the old Pcv valve. Do I need to use some sort of gasket maker/sealer for this or do I just raw dog it?
Old Feb 23, 2026 | 04:13 PM
jgscott's Avatar
jgscott
So how long did it take you on your 2014?
Old Feb 23, 2026 | 04:30 PM
ArgonBlue's Avatar
ArgonBlue
30 minutes draggin ***. 15 of it was spent trying to use a ratcheting wrench or just a basic one. Once I got the crows foot one on there, it was game over.
Old Feb 24, 2026 | 09:03 AM
4GS350's Avatar
4GS350
Part no. 12204-31050 usd12.00 shipped to my part of the wood from Amayama. Changed it when i had the valve cover gaskets replaced.
pigwet
IS F (2008-2014)
41
May 6, 2014 08:42 PM
Choas
Jan 13, 2007 07:28 AM
Davtown
Jul 19, 2004 02:02 AM
