Fuse Box Troubles
Old Mar 19, 2023 | 03:19 PM
Mrke1's Avatar
Mrke1
10th Gear
Default Fuse Box Troubles
Hey all, this may be the "duh" of the week here, but I'm struggling hard with pulling a fuse out of the box under the glove compartment. Any suggestions? I've got at it with a needle nose and all I've do so far is managed to scuff up the plastic part of the fuse.
The 12v plug(cigarette) in the arm rest storage isn't working so my first thought was to replace the fuse. I'm also open to other ideas if anyone has one.
Old Mar 19, 2023 | 04:43 PM
JUTMSS32's Avatar
JUTMSS32
Try something like the following. Can probably find one at any local auto parts store or even Walmart... https://www.autozone.com/electrical-..._0?spps.s=5989
Could also try prying it out with 2 small flat head screwdrivers. I'm surprised the needle nose pliers didn't work.
Did you try pulling a different fuse next to the one you're having trouble with? Maybe that one is just difficult but another is less resistant. If so it could give you the space to get more leverage or a better grip on the one you want. Good luck.
Old Mar 19, 2023 | 05:37 PM
Mrke1's Avatar
Mrke1
10th Gear
I was surprised as well. Hopefully I didn't destroy the top plastic too much, never had this problem before. I'll give that tool a go, I have to head over to a parts shop tomorrow anyway. Thanks for the suggestion.
Old Mar 19, 2023 | 05:56 PM
jkeller's Avatar
jkeller
Isn't there a fuse puller inside the fuse box lid? There must be one inside of at least 1 of the fuse boxes?? the main one in the engine? I've never looked so maybe not.
Old Mar 19, 2023 | 06:28 PM
bclexus's Avatar
bclexus
Here's some advice worth a try. Try using a golf tee to pry the stuck automotive fuse out by using mechanical 1st Class fulcrum leverage against an adjacent fuse or object. A golf tee is non-metallic, relatively strong and pointed which should be long enough to allow you to lever the stuck fuse from its blade fuse holder jaws without concern for shorting out any live metallic contacts.
Or, get a good hold on the little booger with a pair of needle-nose pliers and jerk that fuse out of its socket like a painful, abscessed wisdom tooth.
Old Mar 20, 2023 | 02:07 AM
richard203's Avatar
richard203
i use a needle nose piler to pull the fuse out
Old Mar 20, 2023 | 07:26 AM
bclexus's Avatar
bclexus
Apparently you don't understand what the OP said. He has tried using needle nose pliers, but it's not working for him...
Old Mar 20, 2023 | 07:28 AM
bclexus's Avatar
bclexus
That usually works fine, but not in the OP's case...
Old Mar 21, 2023 | 08:27 PM
atomiclex's Avatar
atomiclex
I have used needle nose pliers with no issues. My cigarette lighter outlet stopped working as well and it was a blown fuse. you should be able to pull it out, also make sure you have the right fuse size! i had to temp use the rear cigarette lighther fuse until i got the right size. I guess japanese cars use smaller fuses that normal.
Old Mar 22, 2023 | 10:48 AM
Mrke1's Avatar
Mrke1
10th Gear
So yeah, I tried the fuse tool but must have got one that was too big, because it didn't work. I eventually just took my needle nose again and pulled very, uncomfortably, hard. Something I would not do again, but it worked. The metal on the fuse was brown, so it must have burnt up at some point in the last owners use. Not sure what happened there. As you state, the fuse is pretty small. My auto parts store had to go in the back to find the size.
pentiumvi
RX - 4th Gen (2016-2022)
41
Nov 12, 2024 09:47 PM
NEWONE1
Sep 4, 2020 08:24 AM
OneSiCkF
IS - 1st Gen (2001-2005)
Aug 14, 2018 01:45 PM
Spyder78
Apr 11, 2016 05:13 AM
skeet92
Jun 29, 2014 07:42 AM
