Advice for TPMS wanings
Old Jul 12, 2023 | 05:43 PM
GSgyro's Avatar
GSgyro
5th Gear
My 2011 GS350 tire pressure warning light is on. The handbook describes how to synchronize the system using a button on the dash. Unfortunately I can't find a button. Does any one know exactly where it is located? I realize the sensor may be bad, but first I would like to check or calibrate it as described for an out of range tire.
Old Jul 12, 2023 | 07:24 PM
lexo98's Avatar
lexo98
When you start the car the light is solid you have a low tire. If when you start the car it flashes a sensor is dead. If you try to push the button on a system with a dead sensor the system might go into lock out mode
Old Jul 13, 2023 | 09:32 AM
ibidu1's Avatar
ibidu1
When your tire light came on did you check all the tire pressure to see if they were good? If you have checked the psi on all 4 tires and they were good. Then more likely the sensors battery have finished. You will need to buy new sensors, I like to use Denso brand, and I purchased them from rockauto. Before you install the new sensor, with your phone snap a clear pic of the serial number, and box of each sensor, you can also write them down just incase. Then have a tire shop mount the new sensors, and see if they are able to program them, if not take it to a mechanic or dealer if you dont have a techstream software. The tech will run his scanner and will clear out the old serial numbers, and install the new serial numbers that you installed.
tranft
RX - 3rd Gen (2010-2015)
76
Oct 7, 2023 05:26 AM
ColdFusion
May 20, 2018 11:42 PM
7Train
May 17, 2018 06:51 PM
pauljcl
Apr 12, 2017 12:49 PM
