Car won’t start
Old Oct 27, 2018 | 06:38 AM
Gsxr's Avatar
Gsxr
Default Car won’t start
Went out to start the car the other morning & it hesitated when finally starting. Went back into house for 5 minutes came back out to leave for work & it wasn’t running but the dash lights were still on. Pushed the start button to start again and the fan came on & there was no cranking at all. Tried to start several more times & the only thing happens is the fan comes on & the dashboard lights up (no crank or not even trying to crank).
Old Oct 27, 2018 | 07:41 AM
potatomon's Avatar
potatomon
first make sure the voltage on the battery is above 12v.
how old is the battery?? you need a good battery for this car cuz of all it's electronics.
I'm not a scientist so take it with a grain of salt but I think If you're trying to start it on 11 volts or something like that you may risk your ecu and other components as the voltage drops even further when you crank the starter.
Old Oct 27, 2018 | 07:45 AM
potatomon's Avatar
potatomon
probably not the battery though, because if it was getting that low the dash wouldn't even light up.. or it would try to light up and then go dim. The radio wouldn't work. Neither would the screen.
See this. https://www.clublexus.com/forums/gs-...-fan-runs.html
It might be the fuel pressure sensor or one of the cam sensors disconnected somehow.
Novembur
Sep 8, 2017 10:23 AM
oslouie
Aug 11, 2011 06:49 PM
eternaldj
Sep 17, 2010 02:46 PM
JoelD
IS - 1st Gen (2001-2005)
Dec 3, 2008 12:33 AM
jimbo22s
Dec 7, 2004 08:12 PM
