Trunk Latch
Old Jun 28, 2018 | 06:00 PM
AshyBone's Avatar
AshyBone
Default Trunk Latch
Hey guys,
So I have a 06 GS300 AWD. My trunk latch just decided to call it quits. Dealership says it's going to be over 900 bucks for JUST the latch. I'm just wondering how hard it's going to be for me to replace it myself. I want to get the part from NOT Lexus, but can't find a trust worthy place to get it from.
Old Jun 28, 2018 | 08:07 PM
guzzy92fs's Avatar
guzzy92fs
Did you confirm its a mechanical problem? My latch decided to quit as well but it turned to be that it got out of programming, disconnecting some cables from the ecu for some minutes and reconnecting solved the issue
Old Jul 3, 2018 | 12:54 AM
AshyBone's Avatar
AshyBone
Thanks for the question, I wasn't sure if my original post was sufficient information.... Which honestly, it wasn't. It's not the actual latch that's bad. It's the motor that's responsible for popping the trunk with the push of the button on the key fob or in the cabin of the car. The trunk still closes and locks, but it just won't open by pushing the button. I have to open it with my key. So I guess the motor is dead. I don't know if disconnecting some cables from the ecu will fix the issue or not. I need the motor replaced which Lexus is saying the motor is 930 something by itself.
Old Jul 3, 2018 | 01:58 AM
ibidu1's Avatar
ibidu1
Have you checked your glove box that the valet button wasnt accidentally pressed. Because it sounds like it is pressed.
Old Jul 3, 2018 | 09:00 AM
PC94's Avatar
PC94
I had the same problem on my '08 GS350. One day, out of the blue, the trunk stopped releasing with the remote or the button inside the vehicle. After cycling the Valet button in the glovebox a couple of times, everything went back to normal.
Old Jul 3, 2018 | 09:10 AM
tghw's Avatar
tghw
It could also just be a bad touch (pressure) switch and not the motor itself.
Old Jul 4, 2018 | 10:24 AM
Propulsion's Avatar
Propulsion
My trunk opens fine but the motor doesn’t reposition the mechanism to close it properly. To close my trunk I have to pull the emergency lever inside the trunk to reset the closing apparatus. The soft close feature was a nice touch but it’s an costly annoyance once something goes array. I will not spend several hundred dollars to replace or repair it. For now, I’ll just use the workaround method of pulling the release lever to close it.
Old Jul 4, 2018 | 10:28 AM
gs350fan's Avatar
gs350fan
Probably a puff of graphite lube in the right place would fix it.
Old Jul 5, 2018 | 08:54 PM
AshyBone's Avatar
AshyBone
I'm pretty sure Propulsion nailed it. The motor isn't repositioning the mechanism so the trunk actually latches. The button in the glove box is pressed now. The original problem was that the trunk wouldn't close AND actually latch so it doesn't open back up. The got the trunk latch working normally, but if I use the motor to pop the trunk, the latch doesn't go back to place. So they have it set up NOW so none of the buttons work. I have to use the key to open and close the trunk. But doing that will at least make sure the trunk stays closed.
Old Jul 5, 2018 | 09:25 PM
Propulsion's Avatar
Propulsion
So it sounds like our problems with the motorized latch are similar. I’ve used the emergency lever to close it for several months and because of its position/location near the latch it hasn’t been too much of an ordeal. Just an annoyance. But I do worry about a valet or someone who isn’t aware of the trunk issue who may try to do a “hard close” while loading luggage, groceries etc which will undoubtedly destroy the latch permanently.
Old Jul 21, 2020 | 07:57 PM
Propulsion's Avatar
Propulsion
Bumping to see if anyone has found a solution to the faulty soft closing trunk latch? I refuse to pay several hundred dollars to replace it.
Old Jul 22, 2020 | 02:02 AM
ibidu1's Avatar
ibidu1
https://www.ebay.com/itm/06-11-LEXUS...0AAOSwkgxetcmr
Install a used latch and motor, $129 Or tear apart yours and see maybe you can put grease inside or a fault may pop up
Old Jan 15, 2022 | 06:29 PM
PlayDude's Avatar
PlayDude
So my trunk struts had given out and I was too lazy to replace them right away, my dealer wanted ~$300 for the pair. Had eventually ordered a pair from AliExpress for ~$20, so just waiting for them to arrive. However, one day when getting stuff out from the trunk, my wife lets go of the lid and it slams shut. Now it won't close properly.
Took it to the dealer to see if it's an alignment problem and they say the "striker" and "closer assembly" need to be replaced. I think that closer assembly is what previous posters have been saying is over 900 USD for the part because there's a motor and electronics that apparently sync with the trunk lid puller motor that works to pull the trunk lid shut. Anyway, I ended up getting those parts on my own from MyLParts and they were very helpful in getting it shipped to me on time. Went to same dealer to get the work done and swap the old parts for the new and they say the new closer assembly doesn't work!
After having read this, which I REALLY should have done before, I am getting the feeling that the part wasn't broken at all and now it just might have been some relay from the glove box trunk valet switch??? $%&@#!!!!!
-VS
Old Jan 15, 2022 | 11:35 PM
ibidu1's Avatar
ibidu1
-VS
When you are not certain 100% that a part has failed, worst thing to do is fire the parts canon in hopes of solving it. Especially high dollar brand new parts from the dealership. Buy used parts off of ebay or local junkyard using www.car-parts.com this will save time and headache. Bummer, the dealership gave you a poor diagnosis.
Old Feb 15, 2022 | 06:32 PM
PlayDude's Avatar
PlayDude
And for the follow-up...
Went to an independent shop to get a second opinion, as I figured there was no way the new closer assembly was broken. They took a few days to diagnose the root cause of the trunk release not working. Turns out he needed to "reset" the ECU for the left side bodywork? Best translation I can figure. He was saying worse case would have been needing to replace that particular unit for about $300 or so. But looks like the reset did the job.
Also did swap in the new closer assembly anyway, as the old one was not shutting properly from being slammed shut repeatedly. So now my trunk is all fixed and working back as normal. Switch, remote button and all.
-VS
