Trunk Latch
Old Feb 15, 2022 | 07:23 PM
Propulsion's Avatar
Propulsion
Originally Posted by PlayDude
And for the follow-up...
Went to an independent shop to get a second opinion, as I figured there was no way the new closer assembly was broken. They took a few days to diagnose the root cause of the trunk release not working. Turns out he needed to "reset" the ECU for the left side bodywork? Best translation I can figure. He was saying worse case would have been needing to replace that particular unit for about $300 or so. But looks like the reset did the job.
Also did swap in the new closer assembly anyway, as the old one was not shutting properly from being slammed shut repeatedly. So now my trunk is all fixed and working back as normal. Switch, remote button and all.
-VS
How much did the new closer assembly cost?
Old Feb 16, 2022 | 06:59 AM
PlayDude's Avatar
PlayDude
I was able to get it for $550 after some discounts. Apparently, there's a motor attached that enables the lock to grasp on to the striker. It also needs to work in sync with the other motor that pulls the trunk lid all the way shut.
-VS
Old Feb 17, 2022 | 10:15 AM
mspearl95's Avatar
mspearl95
-VS
What is the actual point of the motorized trunk latch on these cars? It seems like a needlessly complex system.
Old Feb 9, 2023 | 08:13 PM
3GSOwner's Avatar
3GSOwner
10th Gear
What does "reset the ECU for the left side bodywork" mean? How did the mechanic do it?
Old Feb 9, 2023 | 08:45 PM
PlayDude's Avatar
PlayDude
Well, from what he tells me, there are a few Electronic Control Units though out the car managing various aspects of the chassis/lights/locks/etc distributed from the main control unit, I suppose. The one handling the trunk latch (sense close, lock, release, pull shut) was likely "jolted" electronically or otherwise, from the trunk slam. So he went in through that Toyota/Lexus car management software (cannot remember the name) and reset the unit. It worked, otherwise, he would have had to replace that particular part. Still ended up with a new expensive trunk latch anyway...
-VS
sprtn131
Aug 13, 2015 05:48 PM
panda08
Jun 26, 2014 05:17 AM
Rexus300
Jun 7, 2012 11:26 PM
ZenkiS14
Jul 11, 2009 11:57 PM
beewhyon
Feb 15, 2009 02:58 PM
