Hi everybody,
I'm new here, also new at lexus so Need help cause think I've got a problem ..
recently bought lexus gs 300 2006, and whenever I put the gearbox into "S" it shows that gear is 4th, it works good but sometimes while lunch, it jerks.
So could you tell me if it's normal to show 4th gear in every situation in "s" mode?
even when I stand and move gear to "s" it shows 4th ..
Hope to get help, It kills me
It's normal both GS and IS +at least the ones I have drive) when switched to tiptronic or "S" it goes to 4th gear and you have to shift to first if you are in a stop light.
Thanks guys for your answers, I've just bought it and tested with "s" and etc..
But,
It has problem even in "D" mode .. it's too hard to start slowly from traffic lights, rpm goes on 2 but car doesn't go as it should be, than jerks and goes perfectly
I understand that shouldn't put in "S" but, what have I to do with "D" ???
Did the previous owner(s) keep maintenance records (Carfax etc..)? Unfortunately some owners will patch a major costly issue with a vehicle before doing a quick sale.
At any rate, If you're still encountering a problem in regular drive mode I'd first get a fluid flush with fingers crossed. Also, do some more digging on this website. I recall reading a thread about transmissions and some troubleshooting remedies. Sorry I can't recall which one.
