Dreaded P0420 code been tracking when I get code. Ideas?
Old Jun 14, 2017 | 08:19 PM
whytry's Avatar
whytry
Default Dreaded P0420 code been tracking when I get code. Ideas?
I've read a on of posts on this error code. I wanted to see if anybody else has experienced what I am. I have a scanner and reset it several times and have noticed a pattern. Every time the code shows up it is after I fill my gas tank, it doesn't matter on how many miles I drive, or how I drive, etc it always shows up shortly after the first 1/4 tank is gone and it is in the middle of the next 1/4 tank is when the code shows up. Does not matter if it's 25 miles or 50 or 75. Everytime I get to that spot the lights go off. I have changed the gas cap already thinking maybe that was it. But no luck....
any my ideas or anybody else have the same experience? Or been able to correct it? Lexus told me it's the cat on bank one and it's costly. Trying to resolve it myslef
Old Jun 15, 2017 | 02:13 PM
rickdestik's Avatar
rickdestik
If you have the TIS adapter and software you can set it to capture the data when the event occurs (although I have not done this).
Old Jun 15, 2017 | 04:43 PM
guzzy92fs's Avatar
guzzy92fs
Downward O2 sensor check if its working properly, how is your fuel consumption?
Your catalytic converter might be almost over or clogged, sometimes giving it a good cleaning ( pure lacquer cleaner or seafoam) works to remove the code and extend the life, dismounting it and cleaning it througly or at worst case, replacing it.
Old Jun 15, 2017 | 07:20 PM
WeetoGee's Avatar
WeetoGee
I've been having the exact same issue.
Old Jun 18, 2017 | 09:59 AM
whytry's Avatar
whytry
Milesage is good still and even passed CA Smog test!!
Old Jul 19, 2017 | 10:38 PM
whytry's Avatar
whytry
Has anybody here done this and had it work?
Old Jul 19, 2017 | 10:43 PM
AkumaUCF10's Avatar
AkumaUCF10
https://youtu.be/kzm52m0AWSQ
Save yourself the hassle and just buy a blox O2 extender they're like 5 bucks on amazon
Old Feb 2, 2018 | 01:10 PM
whytry's Avatar
whytry
bought the extender and still having the issue.... HELP
Where can I get the TIS software/etc?
ta1972
Feb 17, 2022 02:18 PM
Dukenukemx
Dec 28, 2015 09:41 AM
MattyG
Sep 6, 2013 07:34 PM
python
Jan 28, 2008 06:04 AM
JohnGS4
Apr 11, 2007 07:50 PM
