O2 Sensor Problem
Old Oct 16, 2016 | 01:36 PM
netasp's Avatar
netasp
Default O2 Sensor Problem
Guys,
I've been getting O2 Sensor Signal Biased/Stuck Rich (Bank 2 Sensor 1) Code P2198, during summer time it would come back every full tank or so but since temperature is dropping, it started to come back way quicker than that. My scanner shows live data and its showing zero voltage for that sensor, nothing at all.
My question is, knowing I am getting code P2198, is it enough to determine the part # for the sensor? which one? I was also told Bank 2 sensor 1 would require removing the front passenger seat and the center console, is this true?
Thanks
2006 GS200 AWD
Old Oct 18, 2016 | 02:21 PM
Othic's Avatar
Othic
There is a service bulletin for that code. You'll have to take it to the dealer to see what ECU calibration IDs you have. Worse case scenario is you'll have to replace 2 O2 sensors and ECU. Check out the link. And no, you don't have to remove the seat to replace the O2 sensors.
http://www.alflash.com.ua/avtovideo/...SB-0092-09.pdf
Old Oct 18, 2016 | 03:00 PM
pbxcomm's Avatar
pbxcomm
Dumb question..
Gas cap leaking or bad seal?
Old Oct 18, 2016 | 06:29 PM
netasp's Avatar
netasp
Originally Posted by pbxcomm
Dumb question..
you don't get P2198 for Gas cap leaking or bad seal...
Old Oct 18, 2016 | 06:32 PM
netasp's Avatar
netasp
Thumbs up
Thank you, I will check out the link
Old Oct 18, 2016 | 09:37 PM
ibidu1's Avatar
ibidu1
To me it sounds like you may have carbon build up issue creeping up on your door step. I would do a top engine cleaning and replace the plugs, clean out the throttle body.
Old Oct 19, 2016 | 04:55 AM
netasp's Avatar
netasp
It could be, but I want to check out the link that was posted by Othic and see if the ECU was updated first or not. I am not getting any voltage from that sensor and its constant zero. I hope I don't have to go to the dealership, other that that, the car is smooth.
Thank you
Old Feb 4, 2017 | 12:48 PM
netasp's Avatar
netasp
the dealer confirmed it, I need a new computer, 2 O2 sensor, PCV valves and an oil change. I can't however find an older computer with part # 89666-30365. alot of computers with part # 89666-30360 and 89666-30362 but nothing for 89666-30365. New is $1400
MsbTTSupra
Feb 21, 2020 07:27 PM
coug66
Sep 23, 2019 09:33 PM
rz_racer
Jan 19, 2008 12:04 PM
nicos1
Nov 5, 2007 05:47 PM
BklynJay
Performance
Nov 19, 2006 10:39 AM
