Extender wheel stud?
Old Aug 18, 2015 | 10:09 PM
Sleepy2is's Avatar
Sleepy2is
Default Extender wheel stud?
Hey guys so I had to add 5mm spacer so my wheel stud is to short now how many mm do you guys recommend would his work ?
http://m.ebay.com/itm/NEW-GOLD-50mm-EXTENDED-WHEEL-LUG-STUDS-FIT-TOYOTA-LEXUS-SCION-12X1-5-10pcs-G002-/181831009392?nav=SEARCH
Old Aug 18, 2015 | 10:27 PM
XxGoKoUxX's Avatar
XxGoKoUxX
I'd recommend you get ARP wheel studs rather than ebay ones. You don't want your new nice wheels falling off while you're driving on the road.
Not to mention the thousands in damage if something were to happen over your studs.
GL!
Old Aug 18, 2015 | 10:42 PM
Sleepy2is's Avatar
Sleepy2is
GL!
Ok I'll get arp what mm do you recommend I have open lug nuts also with 5mm spacer for the front only no rear
Old Aug 19, 2015 | 10:00 PM
designo's Avatar
designo
Do you know how long your OEM studs are?
You need to get studs that are 5mm longer than OEM. Simple
Old Aug 20, 2015 | 12:43 AM
masboy's Avatar
masboy
CL Folding 25,000
5mm should be ok without extended studs. Or get a spacers with lugs.
Old Aug 20, 2015 | 04:20 AM
uberEJ's Avatar
uberEJ
just an FYI axles and hub assembly need to be removed if you go ARP extended wheel studs. i have a set sitting just waiting to be put on. i tried putting them on and the only way to get enough room to push the bolt through was to pull out the hub assembly. so if someone finds a way let me know becuase i want to put these things on!
on RWD it may be easier since you dont have axles in the front but the rears will still be a problem. since mine is AWD its a problem at every corner lol.
Good luck!
Old Aug 20, 2015 | 09:27 PM
toyotasupr's Avatar
toyotasupr
Good luck!
Fronts
https://www.clublexus.com/forums/gs-3rd-gen-2006-2011/637133-diy-wheels-stud-replacement-with-pics.html
rear
http://my.is/forums/f221/rear-wheel-stud-replacement-diy-412113/#/forumsite/20675/topics/412113
I was able to do the 3rd gen gs without removing any axles. I followed this link for an is. Is the awd that much different?
Old Aug 21, 2015 | 04:48 AM
uberEJ's Avatar
uberEJ
Originally Posted by toyotasupr
Fronts
https://www.clublexus.com/forums/gs-...with-pics.html
rear
http://my.is/forums/f221/rear-wheel-.../topics/412113
i wouldnt really know because ive never had to this on an IS. but for stock studs i can replace them no problem because they are short.
when i tried installing the extended studs there was no way i can get it through. i even removed the e-brake drums to try and get and angle to slide it in (like in the link you posted) and still no go. i think our hubs are different than the IS. unless that guy has shorter extended studs or something.
if someone is able to throw extended studs on their AWD let me know cus i want to put these on pretty badly lol.
Old Aug 21, 2015 | 08:01 AM
Sleepy2is's Avatar
Sleepy2is
It's ok don't put it on and sell it to me!
Old Aug 21, 2015 | 10:07 AM
uberEJ's Avatar
uberEJ
nope because there will be a day when i need to change wheel bearings
streetx
IS F (2008-2014)
Oct 1, 2018 02:00 PM
karasha
Suspension and Brakes
Apr 18, 2013 08:14 AM
zeebra
Aug 3, 2011 11:09 PM
ballin
Sep 12, 2010 01:25 AM
chubby
CL of Southern California
Jul 19, 2007 01:30 AM
