just ran tech stream
Old Jun 1, 2014 | 01:21 PM
burny's Avatar
burny
Default just ran tech stream
on wifes 07 GS350. Did health check and got a couple codes for A/C. B1421 and B1424. Solar sensors and I did the check inside my garage. Was wondering if I did it again out in the sunlight would that clear them? Anyone notice these codes?
Old Jun 1, 2014 | 01:29 PM
frmUkraine's Avatar
frmUkraine
I saw such codes on my RX 2007. After they have been erased, they never appear again. Maybe this is one time malfunction?
Old Jun 1, 2014 | 03:57 PM
BinaryJay's Avatar
BinaryJay
Huh, I had no ideas they did this...
DESCRIPTION
The solar sensor, which is installed on the upper side of the instrument panel, detects sunlight and
controls the air conditioning AUTO mode. The output voltage from the solar sensor varies in accordance
with the amount of sunlight. When the sunlight increases, the output voltage increases. As the sunlight
decreases, the output voltage decreases.
The air conditioning amplifier detects changes in the output voltage from the solar sensor.
What's wrong with using a thermostat, jeez...
Old Jun 1, 2014 | 08:50 PM
Majek's Avatar
Majek
Do it outside. You won't get those codes then.
Old Jun 1, 2014 | 10:47 PM
Robertcave's Avatar
Robertcave
Majek is correct if you pit cloth over it or in dark place it will show error code
Old Jun 2, 2014 | 06:07 AM
worker's Avatar
worker
DESCRIPTION
they can't use the light sensor to do temperature, it's completely different. You are reading it wrong.
I am guessing the thermostat and light sensor give the same feed to the computer. They are 2 different feed but they act the same, the feed for that sensor increases and decrease and the computer need A/D to translate that voltage to digital.
Old Jun 2, 2014 | 07:08 AM
BinaryJay's Avatar
BinaryJay
Well, what they're saying is basically if the sun is stronger run the A/C "more"... but if you're setting cabin temperature and want to maintain it you only need a thermostat. Perhaps what this accomplishes is to allow the A/C to run at a more reasonable power level as to keep it on more constantly at a lower power rather than doing a lot of short cycling at full power. It still seems strange to me - way too many little things to break in cars these days.
Sitalo
May 28, 2025 08:15 PM
daman6052
Jun 7, 2017 12:27 PM
O1GS43O
RX - 1st Gen (1999-2003)
19
Aug 15, 2011 04:17 PM
smerre01
Jan 25, 2009 03:36 PM
palaka
Feb 21, 2008 10:27 AM
