Major help needed!
Old Dec 27, 2013 | 08:00 PM
shivam's Avatar
shivam
Default Major help needed!
I can't believe this happened to me, but I was lucky enough that this happened at night. I'm driving home from work around 10:15pm and driving around 45mph; I switch my car from the manual mode to automatic and all of a sudden my car skids 40 feet and just stops. No lights on the dash, just completely stops and locks up the rear tires. I am in the middle of the road at this point and try to restart the car and put it into drive and the car just jolts forward and makes a grinding noise. I was still in shock at the moment, and a cop pulls behind me and asks me what is going on and I tell him the situation. He says he needs to call a tow truck to move the car. I brought it home and now I don't know what to do. The car is a lexus 2007 gs350 awd with about 104k miles, I don't think the car should just stop while driving 45 mph and come to a skidding stop. If anyone can tell me what I should do, should I call lexus corporate, or my dealership. I'm the second owner on the car. I can't drive the car anywhere so I have to tow it wherever I take it. So please if anyone can help me.
Old Dec 27, 2013 | 09:48 PM
rjk's Avatar
rjk
Was the trans fluid flushed at 90k or so (recommended maintenance)? It sounds like a gear stuck just at the very worst time and position.
Old Dec 27, 2013 | 10:24 PM
ibidu1's Avatar
ibidu1
Never heard of anything like this happen, but to me it sounds like to me you may have a blown transmission, or somehow shattered the rear differential.
Old Dec 27, 2013 | 10:33 PM
shivam's Avatar
shivam
I just looked at the recall list for our lexus, and the variable valve timing control device has been recalled"it says that the car can suddenly stop while driving". Do you think this could affect it?
Old Dec 28, 2013 | 06:17 AM
XxGoKoUxX's Avatar
XxGoKoUxX
I doubt that. The car locking is exactly what ibidu said. The AWD system may have seized, because you failed to do your scheduled maintanence. Transmission fluid should be changed every 90k mi, and your rear diff fluid needs to be changed every 30k.
Old Dec 28, 2013 | 06:24 AM
alchemist's Avatar
alchemist
You're trans sounds like it is toast. Go to a tranny shop first not the dealer. Most dealer's won't repair tranny just replace. See what the experts can do first using your existing tranny.
Old Dec 28, 2013 | 08:53 AM
chuckGS350's Avatar
chuckGS350
Service manual doesn't call for tranny fluid changed at 90K or rear diff fluid every 30K.
I still haven't changed my rear diff fluid. I changed my tranny fluid at 45K miles.
At 94K miles, I still debate if I need to change my rear diff fluid.
To the OP, I would register your car with lexus.com to see what service history your car has.
Was the car well maintained before you bought it?
How long did your car stay in manual mode at 45 mph?
Old Dec 31, 2013 | 04:47 AM
promethus7's Avatar
promethus7
Not to sure about the diff every 30K. I took mine in to have it changed at 30K and the dealer looked at me like I was crazy. He said they normally dont service them until 60k however inspected the fluid anyway just to be nice. Said it was still clean and no need to change it
Old Dec 31, 2013 | 06:26 PM
jre002's Avatar
jre002
Where did the OP state that he failed to do his scheduled maintenance?
Even so, very unlikely that transmission will lock up because someone is 10k past changing fluids. Seems like something else happened or contributed to this.
TruPlaya26
RC F (2015-present)
Dec 30, 2015 07:18 PM
Bambam350
May 30, 2014 04:32 PM
RCM83
IS F (2008-2014)
Apr 15, 2013 01:31 PM
syndrax
Dec 20, 2011 06:59 PM
G1G
Mar 9, 2009 02:02 AM
