Old Dec 15, 2014, 04:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Gs350 side mirror lights
Old Mar 15, 2013 | 11:41 PM
isam250's Avatar
isam250
Yea hopefully tomorrow!
Old Oct 30, 2013 | 02:45 PM
ka0bit0's Avatar
ka0bit0
Question
Originally Posted by ashley1977
This is how to replace the bulb without remove the mirror cover, use a putty knife or something flat.
Attachment 276211
Attachment 276212
There are 2 plastic tabs holding the straight edge in, once those are cleared can just remove the house
Attachment 276213
Attachment 276214
Just so I have this perfectly correct. Doing this method requires not even looking at the mirror ? lol
and sorry to bring up an old thread
Old Nov 11, 2013 | 12:11 PM
ValnVer's Avatar
ValnVer
I can vouch for this method. It works!! Took me approximately 15 mins to do BOTH sides (10 mins for the first, 5 mins for the second since I was more comfortable after having done it once).
I used a very small flat head screw driver and covered it with masking tape. I also used the flattest plastic knife I could find to help me hold one side open as I continued to pry along the edge (in the pic I believe a fork was used). You can tilt the mirror and loosen the bottom screw closet to the door (DO NOT remove it all the way) this helps a lot as it gives you a starting point to begin prying. This method does require a little finesse but it's very easy to do w/o causing ANY damage.
Also, I have a 2010 GS and despite what I've seen in other post you CAN NOT tilt the glass to get to both bottom screws (no matter how much you try it's not possible to get to the bottom screw farthest from the door, you'll just strip the screw), perhaps other model years are slightly different, but I don't know. I've seen this done on the '09 and '10 IS but not the GS.
Further, I cannot speak to the "remove the mirror" method as it seems to have worked for many people but I can say this, I tried this method MANY times and with a significant amount of force the mirror WOULD NOT BUDGE. There's no way I was going to risk breaking & having to replace my mirror to install a $15 LED, which is what lead me to the pry method.
Admittedly I was a little apprehensive about this method initially but if I was able to do it (with the relatively small amount of automotive expertise I have) I'm confident that most of the people on this forum would be able to do it. It's a really understated mod but looks really good. Good luck!
...Sorry for the long post and to bring up an old topic
JB5674
Nov 19, 2013 08:58 PM
SilentWish
Sep 1, 2010 08:33 PM
starstreak
Dec 21, 2006 07:21 PM
brian lin
Jun 6, 2005 10:00 AM
Ladyt
Sep 3, 2004 11:17 PM
