DIY: USB Power from Rear View Mirror?
Old Mar 5, 2013 | 02:14 PM
User 121523's Avatar
User 121523
Question DIY: USB Power from Rear View Mirror?
I got a car video recorder after some crazy truck decided to change lane almost into my side while on the freeway. It works great, but I don't like always having to plug in the power adapter to the cigarette lighter and have the cable dangling all over the place.
Has anyone tried drawing power from the cables behind the center rear-view mirror and making that into a mini USB connector? Is this even possible, or do I need to pull cable from the dash and run it through the A pillar and roof liner?
I did try searching on this forum. While I saw a lot of cool custom jobs, I was hoping for something I could do as a DIY project, so I'd appreciate any instructions you might have.
In case anyone is interested, the unit I got was a Garmin GDR35 from Taiwan. With 1080p, wide angle, G-force sensor, and GPS data recording.
Old Mar 5, 2013 | 02:38 PM
worker's Avatar
worker
never heard of anyone trying this.
I think the cop can also use it against you.... especially the GPS part.
Old Mar 5, 2013 | 05:29 PM
BinaryJay's Avatar
BinaryJay
USB is 5V, chances are the feed there is 12V. Additional wiring of a transformer would be required.
Old Mar 5, 2013 | 05:54 PM
2KHarrier's Avatar
2KHarrier
A good idea, never the less.....
Old Mar 5, 2013 | 08:58 PM
worker's Avatar
worker
just looked it up on youtube. It looks great. clear enough to read license plate during the day. At night seem the glare make it unreadable.
Old Mar 6, 2013 | 05:34 AM
Ironman50's Avatar
Ironman50
Yes, it is possible. I just got a radar detector mount mounted into the mirror's electrical system.
Old Mar 6, 2013 | 07:47 AM
EyeKutr's Avatar
EyeKutr
There are mini 12v usb adapters all over ebay, so they will take the 12v and make it 5v etc internally. Easy, just go find the 12v and ground and wire it up.
Old Mar 6, 2013 | 11:09 AM
User 121523
Thanks, all. Where can I find a diagram of the wiring in the small panel behind the rear-view mirror? I'd like to try this myself, but I'm worried about ruining the electricals. On the other hand, I heard it costs ~$200 to do it at a local professional shop, so I might try my luck.
The cop can indeed use it as evidence, but you're not required to give it up unless they have a warrant. Also, even if the plates cannot be perfectly read, a lot of times it's the presence of such device (and the possibility that something was recorded) that makes people behave
Old Mar 6, 2013 | 12:34 PM
patricksr5's Avatar
patricksr5
These cameras are used a lot in Asia and Europe.
Old May 22, 2013 | 08:25 PM
User 121523
I found this kit:
http://www.edotechsupply.com/servlet...igation/Detail
and these instructions:
https://www.clublexus.com/forums/gs-...-detector.html
Thinking about giving this a shot. Any thoughts?
Badasilva1
Aug 16, 2016 12:42 PM
mannym
Mar 27, 2016 11:29 AM
FishBike
Sep 14, 2014 03:10 AM
rusamur
Apr 17, 2014 11:05 AM
italiandud
Dec 12, 2007 10:01 PM
