Check Engine VSC=NO PROWER help PLS
Old Jun 16, 2012 | 08:42 AM
bklynjoker's Avatar
bklynjoker
Default Check Engine VSC=NO PROWER help PLS
STRESSED - I got in the car and drove off - 3blocks down engine and VSC came out and all power shut down to 1000RPM (15mph) nothing more nothing less - i rolled all the way home like a idiot on 20's
Parked and unplugged battery - replaced gas cap and still with same problem.. Does anyone have helpful info please.
06 GS300 90k
Old Jun 16, 2012 | 08:58 AM
XxGoKoUxX's Avatar
XxGoKoUxX
get your local autoparts store, OR purchase a CEL-device and check it yourself, last i checked they only cost you 50-100$. This will probably save your butt forever too!
Old Jun 16, 2012 | 10:32 AM
passnu2's Avatar
passnu2
did you disco the battery for 45 min or more? if not try that as it wont clear the codes stores by just a quick disco. If they come back they you have an issue and need to pull the exact codes.
Any recent work done to the car or mods that we are not aware of?? details will be your best friend for us to help
Old Jun 16, 2012 | 10:52 AM
bklynjoker's Avatar
bklynjoker
Update. Batt disconnect over night - connect,started-20sec later engine light & (!) light came back check VSC - RPM went crazy. Its sitting at 2,oooRPM- Hit in "R" and car stalls out- cant get to autozone now to see which O2 is faulty- gotta buy a OBD reader now. everyone keep fingers crossed for good weather, pulling out Gsxr1000 for work. beyond stressed. About to do insurance job
Old Jun 16, 2012 | 12:37 PM
XxGoKoUxX's Avatar
XxGoKoUxX
it bites, but when it is fixed, you'll feel much better. My car's headed to the dealership in an hr or two because i'm soo dissatisfied with the suspension work they've just recently done
Old Jun 16, 2012 | 04:22 PM
bklynjoker's Avatar
bklynjoker
Ok bought a code reader and it gave me p2111- TAC stuck in open position. Which means throttle plate was stuck and couldn't move- Took it around, turns out a piece of rubber from somewhere was blocking the plate from moving... A few starts and back to normal. Thanks for replies n ideas.
Old Jun 17, 2012 | 08:57 AM
XxGoKoUxX's Avatar
XxGoKoUxX
glad everything's resolved! And maaaan, that's the best investment you've ever done! I'll have to eventually buy one myself when my car starts throwing codes lol
Old Jun 17, 2012 | 10:33 AM
passnu2's Avatar
passnu2
Awesome that scan tool will come in hand down the road
Old Jun 18, 2012 | 07:11 PM
BinaryJay's Avatar
BinaryJay
Air filter wasn't seated correctly or something?
Old Jun 18, 2012 | 07:40 PM
Brian@Vossen's Avatar
Brian@Vossen
Former Sponsor
Thats awesome
Old Jun 18, 2012 | 07:46 PM
XxGoKoUxX's Avatar
XxGoKoUxX
throttle plate, as in the butterfly flap that opens and closes as you change throttle position (in the intake manifold). Honestly, I wonder what the heck kind of plastic/rubber could have gotten stuck in there... luckily it didn't fall straight into the engine, that would of been catastrophic!
Old Jun 19, 2012 | 05:14 AM
bklynjoker's Avatar
bklynjoker
Luckily behind the throttle plate theres a protective gate to catch/block things from flowing in... Ended up cleaning all the carbon build up on plate and MPG went on- atleast on screen
Old Jun 19, 2012 | 06:56 AM
XxGoKoUxX's Avatar
XxGoKoUxX
NICE!.... looks like i'll have some DIY maintanence to do when I get my car back! I'm going at 22-24, but i'm sure i can squeeze more (especially with the upcoming redline oil change)
Old Jun 19, 2012 | 07:04 AM
BinaryJay's Avatar
BinaryJay
Well yeah, but the only way anything foreign could get stuck there is through the intake and past the air filter. So I would check the air box to make sure that everything is seated correctly because it sounds like it sucked in a piece of plastic from the road and it got past the air filter.
Icy350
Dec 9, 2025 11:11 AM
Jbakyy
Jun 2, 2022 06:59 PM
eggwoll
Jul 20, 2017 03:29 PM
HarrierRX300
RX - 1st Gen (1999-2003)
18
Apr 10, 2016 04:16 PM
m8554
Jan 8, 2007 08:44 PM
