maintenance light on?
Old Feb 25, 2012 | 05:52 PM
beaterman's Avatar
beaterman
Default maintenance light on?
Ok so my guage cluster says that my "oil maintenance required" and the red triangle with the ! is on too. I had my oil changed 1300 miles ago and everything on my info screen is reset and good to go. So what does this light and message mean?
Please help me as I have no clue what is going on here.
Old Feb 25, 2012 | 06:04 PM
Bavaria's Avatar
Bavaria
Your owners manual will tell you how to reset the mesage. If you had the service done at a dealer, they should have done this.
Old Feb 25, 2012 | 06:18 PM
bigblack06's Avatar
bigblack06
Was it reset by the dealership or did you perform the oil chage yourself.
Old Feb 25, 2012 | 07:47 PM
beaterman's Avatar
beaterman
It was done at a shop and only the info on the message center was reset. How do you reset the cluster?
Old Feb 25, 2012 | 07:59 PM
AudioBob's Avatar
AudioBob
The reset procedure is in your owners manual. It involves using the reset function switch in the left dash panel and the start/stop engine button. Look under maintenance.
Old Feb 25, 2012 | 08:13 PM
shytown350's Avatar
shytown350
Search YouTube. They have the reset on there
Old Feb 25, 2012 | 08:23 PM
Boron's Avatar
Boron
First & foremost, when did this message appear?
Have you checked the oil level on the dipstick since it appeared?
If not, why not? Get it done immediately!
If that's fine, then get it read for any fault codes.
If the oil is low, I'd have it back to where it was done, and get them to check the oil filter has been correctly fitted & torqued.
I would also query that the Technician filled it to the upper level on the dipstick.
Old Feb 26, 2012 | 06:13 AM
beaterman's Avatar
beaterman
First thing is I have not driven it since the light came on. Also I will check the oil level today. I just figured it wasn't reset properly.
Old Feb 26, 2012 | 07:33 AM
beaterman's Avatar
beaterman
I checked the oil level and its fine. There is nothing leaking from under the car. I'm just gonna reset the light.
lomarica
Jul 28, 2017 06:29 PM
Gladius
Apr 13, 2012 09:34 PM
atomarchio
Jun 25, 2010 10:56 AM
patmcginle
Aug 27, 2008 10:30 AM
carbon
Dec 1, 2006 12:57 PM
