ejecting navi DVD...mine is stuck!
so i got a copy of the gen5.ver 10 navi map..i placed it in my navi slot and as it was rebooting itself, i can hear it having a hard time reading. my screen goes blank and all the buttons on the left side do not work. so i tried to ejecting via "holding INFO button down and turning on headlights on and off 3 times. that menu still does not pop up. can someone pls help! im dying without my navigation here.
did you try keep on tapping different areas on the top right (i hope i remember this right) corner? try different corners, someone mentioned that can get you to tape on the eject button
otherwise, worst case scenario, take out glove box and hit the eject button on the drive itself
not very. take out shift plate, take out right middle side panel, pop passenger side bottom panel, take out knee airbag, unscrew and take out glove box. i can probably do it in a few mins
got it to work...what i did was disconnect the battery. connected it back...pressed ignition twice (no brake) let the system reboot and just tapped the right and left side of the screen.
no navi is making me sad
