XM install
Old Oct 22, 2010 | 06:09 PM
ghd8989's Avatar
ghd8989
Default XM install
I purchased the XM receiver from Sewell however I didn't see a kit to accompany the receiver. Am I not seeing it from the website?
Old Oct 22, 2010 | 06:45 PM
passnu2's Avatar
passnu2
Your car is already pre-wired for XM. All you have to do is mount the XM receiver in your trunk, may have to cut the upper trunk liner, and all the wires you need are on the passenger side. Once you remove the carpet liner all is right there. If you have a hard time look over at the 2gen ISx50 DIY thread. Its the same exact process for your GS
Old Oct 22, 2010 | 11:42 PM
rominl's Avatar
rominl
exclusive matchup
what do you mean kit to accompany the receiver? you mean to mount the xm tuner to the car? there should be two kits you order, one is the xm tuner kit, and the other one is the fitting kit
Old Oct 23, 2010 | 09:37 AM
ghd8989's Avatar
ghd8989
I don't see the fitting kit
Old Oct 23, 2010 | 09:44 AM
passnu2's Avatar
passnu2
it should all be there. I got mine from sewell also when I had the IS and they sent me everything. do you have the parts now?? All it is is the receiver and wire harness for the factory amp.
Old Oct 23, 2010 | 09:58 AM
ghd8989's Avatar
ghd8989
I have not received mine yet. I didn't want to get and then sit idle because I didn't order everything I needed.
Old Oct 23, 2010 | 10:03 AM
passnu2's Avatar
passnu2
sewell will know what you need just order it from Darrel and your all good
Old Oct 23, 2010 | 11:01 PM
rominl's Avatar
rominl
exclusive matchup
yeah call up darrel and confirm. there should be 2 separate kits that you order (2 part numbers)
Old Oct 25, 2010 | 11:34 AM
Sewell's Avatar
Sewell
Parts Vendor
Yes, your order is just fine.
Old Oct 25, 2010 | 07:01 PM
GSLA's Avatar
GSLA
Registered User
Hi Sewell,
I am interested to buy the XM kit as well. However, do you have the instruction for a GS450h, is the installation different from a non hybrid GS due to the battery in the trunk? Want to make sure I can do it before i order.
Old Oct 26, 2010 | 06:45 AM
MadDawg350's Avatar
MadDawg350
Originally Posted by GSLA
Hi Sewell,
Sewell's website provides a link to the install instructions. The install for the350/450h/460 is the same. The mounting point for the sat receiver is up next to the subwoofer and from reading the instructions, it looks very easy to install.
I am going to ask my wife for this kit for Xmas.
Old Oct 26, 2010 | 01:38 PM
Sewell's Avatar
Sewell
Parts Vendor
Click on the graphic below to see the three different options for any of the GS's.
Darrel
Old Oct 28, 2010 | 12:11 PM
ghd8989's Avatar
ghd8989
Is my kit supposed to have this? I thought I was using the shark fin?
I don't see a cable that is supposed to go from the receiver to an empty receptor. This is the only cable I see supplied for an antennae.
File Type: bmp
Old Oct 28, 2010 | 12:46 PM
ghd8989's Avatar
ghd8989
The other thing I noticed is on the options for the XM on Sewell, there are choices for the GS450 and Mark Levinson. I have both so did I receive the right one?
Old Oct 28, 2010 | 05:21 PM
ghd8989's Avatar
ghd8989
Ok. I had the wrong kit for the install. The wiring harness I got from the dealer looked a lot different and the kit had a direct antennae wire instead of the antennae that you would stick on your window.
