Snow/ECT Switch?
Old Jan 13, 2010 | 11:41 AM
Leonard15's Avatar
Leonard15
Default Snow/ECT Switch?
Hi guys I have a 2009 GS 350 Ultra Premium and I was wondering what is that swith in the center console that says Snow/ECT. You can move it forward, backwards or just have it remain in the middle which is where I currently have it. Not sure if it has something to do with when there is snow on the ground or not?
Old Jan 13, 2010 | 11:44 AM
gridlock13's Avatar
gridlock13
the snow setting makes the car start off in 2nd gear to prevent wheel spin. ect power changes the shift points to give you better acceleration.
Old Jan 13, 2010 | 11:57 AM
Yang1815's Avatar
Yang1815
Your car should have come with a manual that explains the features as well.
Old Jan 13, 2010 | 12:44 PM
Leonard15's Avatar
Leonard15
Thanks guys. So do you recommend me putting the switch to snow mode when it's snowing out as right now when the roads are just a tad greasy my car is like on an ice rink and keep in mind I still have the factory tires on them.
Old Jan 13, 2010 | 01:12 PM
worker's Avatar
worker
Sure, y not. That's what it's made for. Keep in mind that you are still the only one with the brain and is the driver. So up to U to decide if it's safe or not.
For me, I keep it slow and let go of the gas paddle when it doesn't feel safe. Since I go slow, the brake can do the job just fine... slip a tiny bit.
Old Jan 13, 2010 | 01:39 PM
BinaryJay's Avatar
BinaryJay
It's been covered before. It seems to make a noticeable difference to me, but for the most part it seems like it's just a governor to keep you from any rapid acceleration. You can keep it off snow mode and just use some restraint to the same effect, just like the good old days.
Old Jan 14, 2010 | 08:19 AM
The G Man's Avatar
The G Man
Sounds like you need some new tires, all the snow mode will do on dry road is slow you down and you can do that on your own.
Old Jan 14, 2010 | 08:34 AM
worker's Avatar
worker
I don't notice it either cause when I know the road is slippery and stuff.. I drive a lot more careful and slow especially around turns.... my baby is too precious to be in accident.
Of course when the weather/road is perfect I will gun it to 120mph.
Old Jan 14, 2010 | 10:00 PM
osokuko's Avatar
osokuko
Yeah I have noticed using the snow setting on the open highway seems to smooth things out and gives a little increase in the MPG department.
Old Jan 14, 2010 | 10:05 PM
arnieosp's Avatar
arnieosp
Originally Posted by osokuko
Try this out, I have noticed using the snow setting on the open highway seems to smooth things out and gives a little increase in the MPG department. Try all three setting and see what happens.
Are you sure "snow" does that? On my car the "power" makes things better. The car shifts at higher RPMs, downshifts quicker, and gas mileage is about 10% better . So, I always keep it on "power".
Old Jan 14, 2010 | 10:18 PM
energie8's Avatar
energie8
Does "power" really improve gas mileage? is it even noticeable? Maybe I should try that out...
Old Jan 14, 2010 | 10:25 PM
osokuko's Avatar
osokuko
Oh I know the kick in the As using the power mode and hand on the shifter in manual at 4th and humming at 70 want to race! But the snow setting on open flat highway seemed to help a little in the mpg, because it slows throttle response down.
Old Jan 14, 2010 | 10:54 PM
Rexus300's Avatar
Rexus300
I agree with the previous post that the sport mode help shift gears faster and with ease and the gas mileage is about +10% better than normal mode. I use this on the highway since I don't have to worry about keeping the pedal pushed longer to keep the speed or higher.
Old Jan 15, 2010 | 05:59 AM
The G Man's Avatar
The G Man
The sport mode is suppose to hold the higher rpm longer and dowshift quicker, and I am not sure if it locks out the highest gear also. If sport mode would improve gas mileage, then Lexus would have made that the normal mode
The snow mode is just retarding the throttle response therefore getting better gas mileage, you can do the same if you really take it easy on the gas pedal.
Old Jan 15, 2010 | 06:08 AM
BinaryJay's Avatar
BinaryJay
If you're on the freeway in sport mode, and switch to sportshift mode it will show that you're in 5th gear. I find myself wishing that it would show what gear you're in when in Drive.
