HELP- windows dont go up or down
Old Oct 29, 2009 | 12:07 PM
hollywoods's Avatar
hollywoods
Default HELP- windows dont go up or down
hi guys,
I just replaced the battery in my gs 350. Now, from the driver side I can not control the passenger windows. They still work, but not from the driver side. There is no blown fuse alert on the cluster.
what can it be and how do i fix thanks
Old Oct 29, 2009 | 12:19 PM
gridlock13's Avatar
gridlock13
manually roll down and roll back up each window from each door. do it several times. then it should work
Old Oct 29, 2009 | 01:12 PM
IXI187IXI's Avatar
IXI187IXI
you have to relearn all the windows. pretty much what was said above. you'll have to use the switch for each window and roll down and up all 4 windows. then the controls on the drivers side should work for all 4. also check your sunroof, its probably not 1 touch anymore.
Old Oct 29, 2009 | 01:23 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
https://www.clublexus.com/forums/is-...isconnect.html
from the 2nd Gen IS FAQ, but applies here as well.
Old Oct 29, 2009 | 09:16 PM
hollywoods's Avatar
hollywoods
thanks, i will try it
Old Oct 29, 2009 | 11:06 PM
I8ABMR's Avatar
I8ABMR
did you recently disconnect the battery??? I remember when they installed my coilovers they ran electrical wiring to run the EDFC and when I picked up the car the windows wouldn't move. They did something and had it working quickly. I hope its a quick fix for you
Old Oct 30, 2009 | 08:30 AM
vietdeluxx's Avatar
vietdeluxx
Go to each window and hold it down all the way. Then pull it all the way up. That should do the trick. This will re-initialize all your windows so that driver side can control all windows again.
Do the same with your sunroof as well too.
Old Nov 1, 2009 | 09:14 AM
varcity64's Avatar
varcity64
how about just taking back to the dealer (assuming its still under warranty)
Old Nov 1, 2009 | 10:06 AM
EyeKutr's Avatar
EyeKutr
LOL I8...he said "I just replaced the battery in my gs 350" I guess you have to disconnect it to replace it.
why would you do that when the fix is so simple?
Old Mar 31, 2010 | 11:06 PM
LexyLisa's Avatar
LexyLisa
So very cool! It worked on my 2006 GS Thank you for your posts everybody!!! SWEET!
rza8gamma
Apr 6, 2011 10:18 AM
Lexminster
Jan 16, 2011 09:01 PM
Kuki_350
Jul 27, 2008 10:32 AM
VTLexus
Jun 18, 2008 09:25 AM
talbin
Sep 30, 2007 10:29 PM
