mirror memory
Old May 28, 2009 | 08:39 PM
coreyco's Avatar
coreyco
Default mirror memory
After I correctly set the seat and sideview mirror memory positions, all is well. But I regularly find myself depressing the memory switch, so the mirrors will go to their preset condition. I'm assuming that perhaps after the mirrors tilt downwards after placing the vehicle in reverse, they don't return to their original position. Since no one else drives this car, I can't think of any other way they would stray from my presets. Anyone else experienced this problem?
Thanks for your input.
-Corey
'07 GS350
Old May 28, 2009 | 09:33 PM
rominl's Avatar
rominl
exclusive matchup
you sure your remote key fob has been set with this particular memory setting?
Old May 28, 2009 | 10:21 PM
Arantant's Avatar
Arantant
Your mirror gears could be failing. I had both mirrors replaced under warranty since they would not go back to the same place after reversing.... after the replacement, I actually turned off the reversing tilt function to avoid the problem in the future.
Old May 29, 2009 | 12:21 AM
Gs350Lola's Avatar
Gs350Lola
Ohh brother i think every lexus is like that. You preset, memorized, reverse the mirror goes down comes back up a different angle. same here. i went to lexus about that problem and they replaced the memory "engine" but it still does the same thing.... I gave up on all my defects on my 07 gs350
Old May 29, 2009 | 05:27 AM
The G Man's Avatar
The G Man
I turn off that stupid tilt mirror feature on every one of my Lexus, they are more trouble than its worth.
Old May 29, 2009 | 10:02 AM
rominl's Avatar
rominl
exclusive matchup
umm, mine come back up to the same angle on all my lexus though. i still wonder if something is wrong?
Old May 29, 2009 | 10:12 AM
07350FROST's Avatar
07350FROST
mine too.
but i have had both mirrors replaced!!
and to answer the OP's question......both your mirrors motors are probly going south. same thing happened to me but not at the same time.
Old May 29, 2009 | 10:43 AM
Stormforge's Avatar
Stormforge
executive matchup
yup, mine is ok too. and i use the mirror tilt down feature every day.
Old May 29, 2009 | 11:54 AM
Orzel's Avatar
Orzel
Hmmm, our 06 GS, and our 05 RX work fine. Love that particular feature in both our Lexus.
Old May 29, 2009 | 01:08 PM
mbasko's Avatar
mbasko
-Corey
'07 GS350
I have the same exact problem. I constant have to reset the driver side mirrow. I took the car in yesterday to get it fixed. They had to order some new parts and I will bring it back when the parts are in. It sounded as though there is a slight modification to the parts I will be receiving. Hopefully, it is a fix for the issue.
Just curious, how do you turn off the feature?
Old May 29, 2009 | 01:18 PM
ivanz's Avatar
ivanz
I believe you put the adjustment switch between in the middle (between left and right) and leave it there.
Fluffymug
Aug 24, 2017 10:23 AM
dano
May 10, 2016 02:57 AM
pman6
Jul 16, 2015 08:07 PM
brel523
Sep 28, 2007 08:56 AM
RAINMN60
GX - 1st Gen (2003-2009)
May 12, 2005 08:18 PM
