Need Help!!! replacing stock sub
Old Feb 21, 2009 | 04:55 PM
j0emamma's Avatar
j0emamma
Default Need Help!!! replacing stock sub
Im tryin to figuer out how to replace my stock sub as we talk. I was wondering if anyone knows how to take out the stock sub on the 3 gen gs asap! can anyone help!!! thanks
Old Feb 21, 2009 | 05:03 PM
passnu2's Avatar
passnu2
Havent taken one out but it either comes from under the trunk, so remove that top liner. A few clips and stuff allows it to come down. See if anyone took pics when installing springs or coils so you can see. If not its from the top and the rear deck lid needs to come out which will probably require the seat to be removed to get it out. wish I knew for sure for you but either way thats what you will have to do. ever consider just putting an aftermarket sub/box in the trunk and an amp?
Old Feb 21, 2009 | 06:37 PM
j0emamma's Avatar
j0emamma
i didnt want to put a sub/box with an amp because i wanted to try to keep the stock look, but anyways i figuer it out. I had to take the rear seats out in order to take out the top liner. There was four bolts that bolted it down and it was sealed on there also. So i had to bang it out when i took those four bolts out.. Thanks for the help tho.
Old Feb 21, 2009 | 07:13 PM
passnu2's Avatar
passnu2
no problem hope it goes well.
Old Feb 21, 2009 | 07:22 PM
jtrue28's Avatar
jtrue28
what size is the sub...10"?
Old Feb 22, 2009 | 03:08 PM
j0emamma's Avatar
j0emamma
yea the stock size sub is an 10"
Old Feb 22, 2009 | 04:28 PM
jtrue28's Avatar
jtrue28
do the ML models have the same speakers, or are those upgraded quality as well? Does Lexus/Toyota still use Fujitsu 10 (Eclipse)...or are they JBL?
Old Feb 22, 2009 | 04:49 PM
Gotcha350's Avatar
Gotcha350
The speakers are the same size and the ML has 4 more. They probably have a different ohm load and watt rating. I do know that the part #'s are different.
Old Feb 23, 2009 | 11:07 AM
joeker's Avatar
joeker
try taking it out the same way as a 2GS.. remove rear seats.. rear head rests.. rear deck and panels.. not too sure but its worth a try
Old Feb 23, 2009 | 11:08 AM
joeker's Avatar
joeker
btw, 4080enclosures makes a custom fiberglass enclosure that helps you keep your "stock" look but runs about ~300$
Patsum
Sep 10, 2013 05:24 PM
Gs3SD02
Jan 24, 2013 03:06 PM
ZippyGuy
Nov 16, 2010 06:04 PM
studaddy
Feb 6, 2003 08:12 AM
gompka
GS - 1st Gen (1993-1997)
Sep 30, 2002 10:42 PM
