DVD Error
Old May 18, 2008 | 10:27 PM
ISFTwins's Avatar
ISFTwins
Default DVD Error
Just got an '08 GS350 Nav/ML and today the CD/DVD player stopped working (wouldn't play, load, eject or change a disk). On the screen appeared DVD Error.. Although I had no actual DVDs in the player, just CDs.. either way it wouldn't play..
I accessed the service menu in the NAV and there are four sets of the error code 45-44.. I don't have any idea how to fix and haven't attempted anything except turning the ignition completely off and then on again .. this did not fix the issue.. If anyone has had the same problem and can elaborate please advise.. Thank You in advance!
WTF??? Car only has 300 miles on it!
Old May 18, 2008 | 10:29 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
There are 2 very easy ways to solve this. 1) Disconnect the battery for at least 15-20 seconds and reconnect...or 2) Take it to your Lexus service dept for warranty.
Old May 18, 2008 | 10:40 PM
ISFTwins's Avatar
ISFTwins
I'll definitely try that in the morning. The though did cross my mind, but didn't want to try anything without the input from others ... Thank You!
(I'm not much of a DIYer as you can tell!)
Old May 19, 2008 | 10:40 AM
rominl's Avatar
rominl
exclusive matchup
are the discs stuck? is the tray door open? can you see the disc?
Old May 19, 2008 | 03:40 PM
ISFTwins's Avatar
ISFTwins
Update :
Went down to get in the car this morning and still have the same problem. I decided to bring it by the dealership and have them take a look at it. On my way to the dealership I was talking on the bluetooth (everything else working fine!) and when I hung up I start to hear the disc player shuffling discs again - which it hadn't done for the last 12 hours. The disc started to play again and the problem went away without doing anything but talking on the phone - could've been a coincidence.. When I arrived at the dealership they read the error code and said the problem was with the disc changer itself and was not electrical (thank goodness). They cleared the code and the problem has not come back today. Lexus will replace the changer if this happens again.. I'll keep my fingers crossed!
Old Jun 16, 2017 | 12:02 AM
Jankardias's Avatar
Jankardias
How about copy the DVD to digital one. I try to copy those DVD when I can't play them with DVD player sometime. And that's proven to be a effetive way. http://www.videoconverterfactory.com...ard-drive.html Hope this solution can fix your problem!
bingogs450
Jan 16, 2011 11:09 PM
Nomi
RX - 3rd Gen (2010-2015)
Oct 26, 2009 07:31 AM
chadfetter
Jun 9, 2008 01:56 PM
speedy203
Nov 27, 2006 06:07 PM
als
Dec 19, 2005 07:33 AM
