Nav bypass issue - Something i did not expect !
Old Oct 10, 2007 | 07:27 PM
EyeKutr's Avatar
EyeKutr
Default Nav bypass issue - Something i did not expect !
I have noticed something goofy....I did the nav bypass / BT bypass months ago, with a switch. here is the thing, driving along,I hit destination button, the 6 large icons pop up, only emergency is enabled if you have not touched the switch, flip the switch and go into address (this disables vss input to nav / enabling addrss entry) and keep driving. Within 1-2 minutes, key pad disables again, you can flip the switch back and forth to allow another few minutes. there must be some redundancy, or the satellite input somehow overrides the lack of VSS, is this only me or has anyone else noticed this. I tested this a few times and it happens this way over and over....why ??? is it my switch somehow allows current through somehow ?? maybe my solder connections are touching (re-enabling signal)
Old Oct 10, 2007 | 07:54 PM
Yang1815's Avatar
Yang1815
Yep, as soon as the satellite signal is calculated to determine your new location, the navigation locks out again.
I believe the interval is somewhere between a minute or two if you want to time it.
Old Oct 10, 2007 | 08:04 PM
2thfixr's Avatar
2thfixr
+1, normal for the hack. Once the car determines that you are actually moving via sat signal, it will lock you out.
Old Oct 10, 2007 | 08:22 PM
EyeKutr's Avatar
EyeKutr
Thanks guys, I had not read about that at all in prior posts....
Old Oct 11, 2007 | 05:13 AM
Yang1815's Avatar
Yang1815
I did I did!!!
I don't even have the switch installed
Old Oct 11, 2007 | 07:34 AM
EyeKutr's Avatar
EyeKutr
more reason to have a switch !!
Old Oct 11, 2007 | 11:54 AM
socalJD's Avatar
socalJD
^ Since you have a '06, can't you just do the override sequence ? What add'l benefits do you get by splicing in a switch ???
Old Oct 30, 2007 | 07:26 PM
Georg's Avatar
Georg
8th Gear
Hello all:
I have a 2006 GS300 with NAV, without ML. I believe it's one of the very first ones produced for model year 2006 (in April 2005). I ejected the (North America) NAV DVD; at the bottom, next to the 9 green dots (arranged 3x3) it has a bunch of of number sequences, and on the third line says "DATA ver.04.2".
I want to do the BT bypass. To be sure ... what generation and version of NAV do I have ? ( I have seen both versions 5.1 and v6.1 mentioned as 5th generation in the forums. Is this a 4th generation ? And BTW, the Menu/Volume Override for the NAV does work. ) And therefore, what instructions would apply ?
Thanks.
Old Oct 30, 2007 | 07:53 PM
EyeKutr's Avatar
EyeKutr
You have Gen 4....ver 4.2 refers to the data map version, latest is 7.1....you need to buy Gen 4 ver 7.1 .....if you want newer maps....
Old Nov 1, 2007 | 07:24 PM
Georg's Avatar
Georg
8th Gear
Thanks, EyeKutr.
So ... this is a Gen 4 system. Will the instructions "Bluetooth Phone Dial-Out Bypass - For Non-Nav 06 GS" work ( https://www.clublexus.com/forums/sho...d.php?t=249372 purple wire #14 on K46) ?
( And I would add the switch to avoid the "stutter" problem on my NAV. )
Out of curiosity when (what model year and/or 2006 model production month ? ) did GS change to Gen 5 ?
Old Nov 20, 2007 | 04:35 PM
ste's Avatar
ste
i have a problem i did the nav and dvd hack yesterday on my gs350. i used a rocker switch. my nav and radio plays fine with the switch but my dvd player is not showing the pictures. i grounded the yellow wire. it played fine yesterday but i had the wires wrong. i had the purple wire from the harness connected to the white/black bullets going to the harness. and i noticed that my switch was workn i couldnt get my turn list but i rewired it. i have the purple wire going from the harness going to the white/black bullet going to the back of the radio. i still have the yellow wire grounded but cant see dvd pics. help pls
Old Nov 20, 2007 | 05:12 PM
Cut-Throat's Avatar
Cut-Throat
Veteran: Navy
No one can help you because we can't see what you did. You obviously mis wired something. You are going to have to Triple Check all of your wiring with the instructions posted on this website. You can find it, you just have to be detailed and take your time.
Old Nov 20, 2007 | 06:05 PM
EyeKutr's Avatar
EyeKutr
https://www.clublexus.com/forums/sho...=1#post3040278
Old Nov 20, 2007 | 08:48 PM
MSL's Avatar
MSL
How Can I Do the bypass to my 3GS NAV/ML ride...
Old Nov 20, 2007 | 10:33 PM
Yang1815's Avatar
Yang1815
There is a sticky...
joeker
Mar 29, 2010 12:00 AM
sbrown02
Jan 8, 2007 09:53 AM
rschiff
Feb 23, 2005 03:23 PM
vipermann1
Mar 25, 2002 08:16 PM
