I need your help!!!!
Old Jun 5, 2006 | 02:29 PM
knicker's Avatar
knicker
Default I need your help!!!!
Whats up fellas I have an 06 gs300 Rwd about 3 weeks ago I put 22's on the car and last saturday the tire pressure indicator light came on and 2 dealerships have told me that their is absolutely nothing they can do.....has anyone had this problem before and if so how do I fix it????????????????????????? thanks!
Old Jun 5, 2006 | 03:42 PM
jwa's Avatar
jwa
22's!!! That's way too big for the GS 300.
Do a search for "Tire pressure sensor" or "Tire pressure monitor" in the 3GS forum, and you will see many threads on this issue. I believe that under some conditions, the Lexus tech can use a scan tool to correct the problem.
Old Jun 5, 2006 | 04:07 PM
knicker's Avatar
knicker
what do you mean way to big????? their is no such thing as to big.......if I could fit bigger I would!
Old Jun 5, 2006 | 06:41 PM
oneeyejack's Avatar
oneeyejack
why do you even ask for advice if you're not going to listen to it? obviously there is some sort of tire size limitation or else you wouldn't be having this problem.
listen to jwa and try to do a search on tire pressure. good luck.
Old Jun 5, 2006 | 08:11 PM
knicker's Avatar
knicker
Default 22's
To oneeyejack I have done alot of research and one I have found doesnt help. I do appreciate everyone saying what they thing will work. Although 22's in my opinion arent not to big.....to big is something that old people say.
So it seems that i need to get the thing reset every 2k miles ? thats not what I wanted to hear...is there anyway to disconnect the thing?
Old Jun 5, 2006 | 08:12 PM
knicker's Avatar
knicker
Default 22's
were are the sensors located?
Old Jun 5, 2006 | 08:31 PM
knicker's Avatar
knicker
Default 22's
fellas I found out how to bypass the sensor!!!!!!! if you have any questions let me know.
Damn computers cant hold me down!
Old Jun 6, 2006 | 01:08 PM
knicker's Avatar
knicker
Default my ride
this link should take you right to my page
http://www.cardomain.com/ride/2350652
also I found the old post about how to trick the ECU into thinking the tires are fine. as for today I went to the dealership and he plugged his computer in and said everything looks fine and the light shut off......kind of strange that all the sensors are reading properly and the light still got tripped????? how confusing!
Old Jun 7, 2006 | 09:55 AM
knicker's Avatar
knicker
well if anybody has any other ideas of how to unsure the light isng going to come back on it would be greatly appreciated. I would rather not hack the ecu apart.
Old Jun 8, 2006 | 11:26 PM
nardeezy's Avatar
nardeezy
It has nothing to do with the size of your wheels. The issue is your TPMS is not detecting tires pressure sensors. Do you still have your OEM wheels with the tire sensors? If so, have a reputable wheel shop remove the tire sensors from your OEM wheels and install the sensors on your 22's. Another question, are your 22's tire sensor friendly? Meaning, can tire sensors be mounted onto the wheels easily (basically with the OEM fitment kit). Typically, if it's a one piece cast wheel you shouldn't have a problem but if it's a multi-piece cast/forged wheel you may need to use the stainless steel straps for the sensors.
I have custom iforged wheels and they were made tire sensor friendly. I did not remove the tire sensors from my old wheels. I purchased 4 additional sensors and fitment kits for approx. $85/ea from the dealer with a coupon. I was cool with the parts department guy and he had a technician program the sensors in as a "2nd tire" after the sensors were installed on the iforged wheels. Prior to mounting the tires I had to record the serial numbers of each tire sensor so the technician could input that data into the computer. If you don't record the serial numbers than they will have to dis-mount the tire to retrieve it. The dealers don't like doing these things and they will charge you a lot of money ($125), some dealers will even dismount and re-mount the tires even if you recorded the serial numbers.
Old Jun 9, 2006 | 10:23 AM
knicker's Avatar
knicker
the 22's that I have do have the sensors in them. they already had a place for the sensors. I actually took it to the dealer and they plugged in their computer and the light went off I am just hoping it stays off.
Benoit
RC - 1st Gen (2015-present)
Feb 6, 2019 03:34 AM
tukai
Oct 14, 2010 12:59 PM
uae
Mar 10, 2008 09:16 AM
mikemareen
Wheels, Tires & Brakes Forum
May 16, 2007 07:43 AM
ant1952
Oct 20, 2002 12:21 AM
