Tire Sensors
Old Oct 15, 2002 | 09:49 AM
ant1952's Avatar
ant1952
Default Tire Sensors
Picked up my new sc430 two days ago right before i left the dealer the tire senor light went on. They took care of it, now two days later it's back on. Is this a common problem that other owners have had. I will call the dealer today.
Old Oct 15, 2002 | 10:52 AM
ceboyd's Avatar
ceboyd
Default not here
I've had my SC430 for over a year now and NEVER had any problems with a sensor light going on.
Old Oct 15, 2002 | 11:58 AM
rcf8000's Avatar
rcf8000
In a year and a half the tire sensor light has come on several times on my wife's SC430. Each time it was because the tire pressure had fallen into the 20s.
Old Oct 15, 2002 | 12:00 PM
ant1952's Avatar
ant1952
Default tire sensor
did you find that there was a problem with the tire or the sensor
Old Oct 15, 2002 | 12:10 PM
rcf8000's Avatar
rcf8000
Evidently a slow leak in the tire. Recently, one tire had a leak of about 2psi per day. Took car to dealer and they said that there was a nail or similar in the sidewall, and that the tire could not be repaired. There was a partial credit allowance toward a new tire, but the whole deal was still pretty expensive.
Old Oct 15, 2002 | 12:13 PM
ant1952's Avatar
ant1952
Well that's too bad. But in my case my car is only 2days with 69miles on it. They better fix it right or put a new tire on!
Old Oct 15, 2002 | 12:50 PM
Larry's Avatar
Larry
My light came on a few weeks ago. One of the tires read 24 psi.
As soon as I checked all 4 and aired them up, the light went out.
Old Oct 15, 2002 | 05:45 PM
1NICESC430's Avatar
1NICESC430
My light came on when I took it out of its snug winter home early this spring. What surprised me was that I had to drive about 5 miles after I put air in the tires before the light went out.
Old Oct 19, 2002 | 12:08 PM
DevilDog's Avatar
DevilDog
The factory is recommending to set the pressure at 40 psi. Have you checked your tire pressures yet? I'd recommend to buy an electronic guage to be accurate.
Let us know what happens.
DD
Old Oct 19, 2002 | 03:42 PM
1NICESC430's Avatar
1NICESC430
Dog ...
While I do not doubt you, I wonder where you got the information that Lexus is recommending 40psi? Some of the folks here have been told 38, and my service manager told me 36.
Old Oct 20, 2002 | 12:21 AM
DevilDog's Avatar
DevilDog
During the SC430 training seminar 40 psi was recommended. The tire pressure light will come on at about 28-30 psi. If the tire pressure is set when the tire temp is about 140F, then when cold (ambient temp) could drop as much as 4-5 psi. Since it's normal to lose about 2 psi a month, the light could come on before your next service if it's set at 36 psi or lower. The 40 psi recommendation has nothing to do with ride or performance quality.
My 2 cents
DD
xanthax
Mar 3, 2009 07:24 PM
omr
Feb 23, 2007 03:53 PM
SC430GA
Jun 7, 2006 04:28 PM
JJRHO
Nov 5, 2003 02:44 PM
JJRHO
Aug 28, 2003 01:17 AM
