2007 GS350 AWD with 184k miles Code : P2757
Where can I buy a
Torque Converter Clutch Pressure Control Solenoid for code p2757 ?
if running out of suspects, maybe remove the ECU and have it serviced. The ECU controls the operation of the solenoids in the tranny.
it seems to be common to 3GS to shift harshly between 1st and 2nd in stop-go traffic, many have had that problem fixed by having the ECU serviced.
My 06 GS300 AWD had that 1st-2nd hard shift problem too. I removed the ECU, took out the PCB, and reflew all major solder joints on it, and that totally fixed the hard shift problem.
Its plausable that the ecu with the transmission module inside has some sort of an issue. Could be corroded wiring, broken wiring, could be a bad ground, etc. But I would take it to a transmission shop that specializes on toyota/lexus. This way they can properly diagnose the issue, without throwing parts at it in hopes of a fix.
Not saying servicing the ECU would definitely fix P2757, but, as the ECU governs the solenoids operation, and the solder joint failure in it has been known to be cause of transmission issues, it seems to make sense to make it the next suspect.
Also I had them change the front cover seal, not sure if that would have had any connection to the trans or not.
They are trying to argue that because they didnt diagnose it, it was my fault and they won't recover rebuilding the transmission.
In the last 15k miles since i bought the car the check engine code for p2757 came on and off irregularly, and every once in a blue moon the clutch would slip a tiny bit but not super bad.
In that time I had taken the car to AMCO 3 times and they did their free transmission checks(not sure if they actually take the pan off or not) I had jiffy lube change the tmf once and lexus change the tmf.
This last time I took it to lexus i asked them what they thought about tmf additives and they said they didnt recommend, so i told them not to put it in. They put it in anyways. And are saying thats one of my mistakes...
I've brought my car to this same lexus service shop probably 6 times for oil changes and repairs in the last 4 months.
I've told them at least 3 times that the transmission was acting a little strange. I told them that it had a transmission code that would come off and on.
I said I didn't want them to do a full diagnostics because it's too expensive and I'd like to just change the solenoid first and if it doesn't fix the problem then I would do the full diagnostics. For some reason(I'm not sure) on my receipt they show a transmission fluid flush(not a drain and fill) so when they went to change the solenoid they flushed it(which could have caused problems) and they cleared the codes.
Then I came and picked the car up and on the drive home the car did not drive very well at all and the transmission code came on after only a few miles of driving, and it didn't come off and on like normal it came on and stayed on and I cleared it 2 times and every time without fail it turned back on consistently. The clutch slipped a lot more and I distinctively smelled a burning smell everytime I stopped and got out of the car. One time when shifting into reverse it had a very rough shift aswell. All of these being things that DID NOT happen before they "changed the solenoid like the customer requested" also all of these happened within 48 hours of picking up the car and less than 100 miles of driving, and I brought it right back to lexus in that same time. I feel like lexus jipped me here and I'm pretty upset.
1. If they test drove the car they would have instantly known there was a problem and let me know. Instead they either didnt test drive it, or just cleared the codes and let me pick it up trying to hide it.
2. They put in the tmf additive anyways agianst their OWN recommendation, and after i agreed and said okay nvm dont put it in.
3. They did a transmission fluid flush not just a drain and refill without telling me. And they did the flush when they changed the solenoid so if there really was physical clutch damage wouldn't that have come out with the flush? Not when they dropped the pan after they let me drive away with a practically destroyed transmission?
This is all i know for now.
Im going to ask them to diagnose why the clutch actually broke and go from there. A small amount of slip isnt going to cause catastrophic problems over night.
not sure if its possible to even put a solenoid in wrong, but even if that wasnt the correct part that needed to be fixed it shouldn't have caused MORE problems.
I'm going to request that they cover the damages and im going atleast try to uncover why this happened and what's best to do about it for future people. They quoted me $3.3k to rebuild the transmission(even with employee discounts that I get) which is another reason why it'd be better to try to hide their mistake, if they made one, and not try to say it was all on me because I didn't want to pay like $650 for a full transmission diagnostics.
If you have any ideas, thoughts or advice please let me know.
Or if you would like any more info lmk
Thank you.
if there are lexus admins here help would be appreciated too😂
@Lexus
Theres a site called www.car-parts.com it will help you search salvage yards for a used transmission. When you do install the new/used transmission I would only stick to toyota WS fluid, with a oem filter.
2010
Transmission Assembly
Lexus GS350 NR,A.T.; AWD 69,656 A $W09333 $400 LKQ-Keystone-Las Vegas USA-NV(Las-Vegas) 1725salesmanagement@lkqcorp.com?subj...Postal%2084001 800-551-5331
it actually feels like it got worse
