New actuators door lock programming issue.
Old Nov 30, 2020 | 12:34 PM
harshybar's Avatar
harshybar
Default New actuators door lock programming issue.
Hey fellow Ladies/Gents. I have a 2000 GS300, I recently had all of my door lock actuators replaced. Now my door locks don't work. So based on my search I did the whole door open, lock/unlock dance. The car just doesn't go into programming mode. Is there an alternative way to program the door lock feature from the fob?
Yes the locks work when using the door switch.
Old Nov 30, 2020 | 09:44 PM
lexo98's Avatar
lexo98
What actuators did you replace them with? Also when your doing the reprogramming don’t use the auto door locks to lock/ unlock. Use the manual drivers door lock.
Old Dec 1, 2020 | 09:39 AM
jefthim's Avatar
jefthim
I agree with lexo98 - you need to understand the source of the replaced actuators. There are some well documented threads as to the issue with the cheap EBAY replacements that will cause the issue you have noted. Have you also verified that you have a master key to do the programming?
Old Dec 2, 2020 | 07:22 PM
harshybar's Avatar
harshybar
Amazon Amazon
these are what I bought.
I am using the master key.
Old Dec 3, 2020 | 04:28 PM
jefthim's Avatar
jefthim
Originally Posted by harshybar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 these are what I bought.
I would bet those actuators are the issue. I had a similar issue when I worked on mine. As noted, there is allot of documented cases regarding the cheap actuators.
https://www.clublexus.com/forums/gs-...l#post10632052
https://www.clublexus.com/forums/rx-...-tutorial.html
The guy knows his stuff and sells rebuilt OEM actuators on ebay. I bought new ones from him and it fixed my issue. I hope this helps!
https://www.ebay.com/itm/Lexus-GS300...72.m2749.l2649
In my experience when it comes to replacement parts with these cars...it's best to have Toyota OEM parts.
Old Dec 4, 2020 | 06:24 AM
harshybar's Avatar
harshybar
Thank you for the detailed information. I will see if I can order them and install those.
Old Dec 8, 2020 | 05:05 AM
JonGS3's Avatar
JonGS3
Yeah they're junk. You can check my post history. I went through issues with the cheap actuators too. Just buy the OEM ones and be done with it.
Old Dec 9, 2020 | 11:34 AM
sunpadre's Avatar
sunpadre
Last year I purchased a similar type of actuator set on Amazon and installed them on the 3 doors that had failed - rears & driver. They all work fine but have one hiccup. When the alarm is on, if I unlock the driver door with the key, the alarm will activate. I guess these more affordable actuators don't have the advanced electronics in them like OEM. It's not a huge problem, since I now can unlock with the key FOB button which is what I was going for anyway, but interesting to note.
Old Dec 25, 2021 | 03:42 PM
QLex300's Avatar
QLex300
Thanks for this info, my passenger font door is having these issues and was about to get the ones on amazon, but will get 4 from the guy in your post!!
Old Dec 25, 2021 | 05:43 PM
lexo98's Avatar
lexo98
Buy the motors and mini gear puller on eBay and do it Yo self
BrendanS
Jun 3, 2018 08:55 AM
Silvermtb6
Jul 15, 2012 11:53 AM
BLK98GS3
Jun 3, 2012 07:25 AM
Chris98vob
GX - 1st Gen (2003-2009)
Mar 3, 2007 09:19 AM
