Delayed shifting
Old Sep 8, 2003 | 10:39 AM
ballin's Avatar
ballin
Default Delayed shifting
I just recently installed an aftermarket CAI (Cold Air Intake) into my 99 GS3, and noticed my shifting is delayed. Like its in Power mode selection. It shifts at a higher RPM then the stock air box. Have any of you had this problem after installing a CAI? If you did have this. What did yo do to remedy it, or is this normal?I noticed this on my other car when I installed a CAI. It took the ECU a week to adjust the new system, and turned off the CEL (check engine light).
Old Sep 8, 2003 | 12:38 PM
Letsride's Avatar
Letsride
Question
Did you reset the ECU after the install?
Old Sep 9, 2003 | 10:09 AM
ballin's Avatar
ballin
How do you reset the ECU?
Old Sep 9, 2003 | 10:46 AM
Letsride's Avatar
Letsride
Remove the neg battery cable for at least 20 minutes will do or remove the ecu fuse for the same time.
DakaDan
Aug 15, 2021 09:34 AM
awesomefar
Jul 12, 2018 10:21 AM
marsmango
Sep 12, 2017 04:32 PM
The Ikon
Mar 26, 2001 10:31 PM
The Ikon
Performance
Mar 26, 2001 07:31 AM
