Serious Door Lock Problem
Old Apr 4, 2016 | 09:21 PM
heynamesmi's Avatar
heynamesmi
Default Serious Door Lock Problem
Hello Everyone, I just purchased a 2001 Lexus GS300 and I really need my front passenger door to lock. All of my doors unlock via inserting the key and door lock button except the passenger side. When I press lock or unlock using the button inside, you will here the sound twice. Also, my key fob does not work, I tried programming it again but it seems it does not want to work, could it be the passenger side not locking causing the problem?
I tried manually locking the front passenger side but it doesn't seem like it wants to so what is the problem? Is the cable not connected because if it was just the actuator, I am assuming you can lock it manually but this is not the case because it freely moves loose.
Old Apr 4, 2016 | 10:10 PM
lexo98's Avatar
lexo98
Start here. https://www.clublexus.com/forums/gs-...-broken-3.html
Old Apr 4, 2016 | 10:18 PM
heynamesmi's Avatar
heynamesmi
Originally Posted by lexo98
So the door lock moving freely and being loose could be the result of the cable rather than the actuator? (I'm assuming because it moves freely and doesn't stay in place) also could this lock not working cause my key fob to not work?
Old Apr 5, 2016 | 10:49 AM
lexo98's Avatar
lexo98
If the lock moves freely it is probably not connected to the actuator. Probably a damaged or disconnected cable. Your not going to know for sure until you get that door panel off
Old Apr 5, 2016 | 11:56 AM
ksultan78's Avatar
ksultan78
this happens to everybody on this forum. You can purchase a new assembly / wires off ebay. Good luck. Its not a difficult fix by any means. Follow the link lexo98 posted.
Old Apr 7, 2016 | 03:40 AM
heynamesmi's Avatar
heynamesmi
So glad it may just be the cable and not the actuator, could this door lock problem cause my key fob not to work because the passenger side wont lock or unlock?
Old Apr 8, 2016 | 05:06 PM
heynamesmi's Avatar
heynamesmi
I fixed it, both my manual lock and key fob works now. However the actuator is bad though, my key when inserted into the passenger door doesn't unlock or lock, would the that be the actuator too?
Old Jun 17, 2020 | 08:32 PM
jacslater's Avatar
jacslater
Had the same problem. It was getting too annoying. Dunno much about fixing cars but I got this locksmith to do it and they did a great job thank god!
Old Jun 20, 2020 | 12:48 PM
Ttouch's Avatar
Ttouch
How much did he wind up charging you? Did he replace all 4 actuators?
rkoz
Sep 5, 2012 06:35 PM
ALLWiTE2JZ
Jun 28, 2010 08:36 AM
vinh
Jul 3, 2009 10:49 PM
OkieState
Oct 16, 2008 12:15 PM
