Trans cooler line location
Old Oct 12, 2014 | 12:30 PM
Deadpool88's Avatar
Deadpool88
Default Trans cooler line location
Are these them? They look like they run all the way back and I can't think of what else they could be. The one I'm pointing to is on the passenger side and the other one you can see heading towards the driver's side. Also which is the feed? Ill take better pictures when I get under it, I didn't see any pics when looking through the transmission fluid change threads.
Old Oct 12, 2014 | 04:04 PM
Deadpool88's Avatar
Deadpool88
Figured it out, the one I'm pointing to is the return, the one on the driver's is the feed.
Replaced 10 quarts, took about 20mins with a helper.
Old Oct 13, 2014 | 04:49 AM
burny's Avatar
burny
sorry I was late to the party, but you have it correct. I have done it twice on the 02 GS300. Usually do 3 quarts at a time taking old out and refilling with same amount.
Old Oct 13, 2014 | 10:53 AM
Deadpool88's Avatar
Deadpool88
That's what I did, except in 2 quart intervals. Once we got 6 quarts out the new fluid started to show (for the most part) and we stopped at 10.
Old Oct 13, 2014 | 11:32 AM
burny's Avatar
burny
nice. You should see what a ppain in the a$$ it is to do the so called sealed trannies. Makes that job look like fun.
Old Oct 13, 2014 | 11:45 AM
Deadpool88's Avatar
Deadpool88
My dad has an 07 LS460 and was wondering how hard it would be to do it on his, doubt its anywhere near like it is for most pre 05 models.
Old Oct 13, 2014 | 02:20 PM
burny's Avatar
burny
it is similar to what you did but you use the drain bolt to drop the 2-3 quarts at a time and refill same amount through the fill hole. It is the top off procedure that is a pain. You have to jumper 2 pins on OBD and let car reach operating temp. Then you fill until fluid trickles out the overflow tube..there are write ups in the GS350 forum
Old Oct 13, 2014 | 02:25 PM
Deadpool88's Avatar
Deadpool88
Yeah it sounds like a *****.
av8trmech
GX - 1st Gen (2003-2009)
Feb 23, 2019 10:20 AM
acklac7
Dec 20, 2017 10:03 AM
colenzae
RX - 1st Gen (1999-2003)
May 22, 2016 02:36 PM
redjeeper
Maintenance
18
Oct 4, 2014 07:47 PM
cmc07e
Jul 29, 2007 07:36 AM
