My car has 158k miles on it and its take longer then usual to start up after the engine is warmed up. Could this mean I need a tune up. I got my valve cover gasket done recently and they said there aas oil in the spark plug alley before they changed it. Any help is appreciated.
Ima buy one tommorow n see if that fix the problem. Keep yall updated
Most auto part stores will test it for free. Might be worth checking your current battery first then spending the money on a replacement only if needed.
I would start by testing the battery. It may be getting to the end of its life.
I change the battery n still same problem. Is there something besides the spark plugs thst could csuse this to happen? Cold start up fine n fast. When engine is warm. It takes longer then usual.
