Battery problem?
Old Jun 22, 2010 | 10:20 AM
GS-power's Avatar
GS-power
Exclamation Battery problem?
i mentioned before that i have week in car electricity, and i think the problem solved. but now my battery seems to be dead, when i charge it the car start normal, i keep the car running, then i turned it off, after 30 mins i check again and the same problem happen. i had this battery from one year, so is it a battery problem or not?
thank u
Old Jun 22, 2010 | 10:33 AM
Mr Jokster's Avatar
Mr Jokster
Sounds like its not holding a charge. Best thing to do is take it in to auto parts store and have it tested.
Old Jun 22, 2010 | 10:46 AM
o6spdracer's Avatar
o6spdracer
And if you have had it for 1 year (not sure if you meant 1 year or if its the original battery), it should still have a warranty. If not, get a new battery.
Old Jun 22, 2010 | 06:36 PM
Rich23's Avatar
Rich23
On way to find out if its definately the battery is turn your headlights on and start the car and see how much they fail to light up or if they go completely off when you try to start the car...
If the car starts up then disconnect the one of the battery polls from the battery, if the car shuts off then it is not your battery, its the alternator...
If you have a voltmeter though you can just test the voltage, anywhere from 12-14v is good. If you are getting lower when car is on then it is definately the battery...
Keep us posted...
Old Jun 23, 2010 | 06:55 AM
ydjy's Avatar
ydjy
Never disconnect a battery when the engine is running. It may burn your alternator.
Battery warranty does not cover damage caused by incorrect charging voltage.
Anyway. Either your battery does not hold charge, or something is discharging it when the car is off.
Old Jun 23, 2010 | 08:27 AM
GS-power's Avatar
GS-power
i tried to disconnect the battery when the car is running, the car didn't turd off, so it might be from the battery or something is discharging it.
Old Jun 23, 2010 | 08:32 AM
exodus_2's Avatar
exodus_2
you might have short on some where that drains battery when it's not running...
sounds like your alternator is working fine but when ever it's not charging the battery dies right???? if battery don't hold charge it won't even start the car unless you have jumper or other power source attached to it. might want to check any electric work you did on your vehicle recently
Old Jun 23, 2010 | 09:16 AM
Rich23's Avatar
Rich23
Check voltage on battery when car is on as compared to when it is off... Then you can properly diagnose...
Old Jun 24, 2010 | 02:49 AM
GS-power's Avatar
GS-power
Hi guys,
thanks for the reply, i tried to something clever, so i charged the car then i turned it off and disconect the battery. i left it for a while then i connected the battery again but no charge in the battery and my car didn't start, so what do you think.
Old Jun 24, 2010 | 03:10 AM
Mr Jokster's Avatar
Mr Jokster
as already concluded, you need a new battery.
Old Jun 24, 2010 | 04:01 AM
Rich23's Avatar
Rich23
I didnt say to do disc. the battery for a while (actually I didnt mean that). It was just a old diagnostic trick. thanks for the heads up on that though...
Old Jun 24, 2010 | 05:13 AM
Mr Jokster's Avatar
Mr Jokster
yea, nothing wrong with removing plug, obviously dont want to sustain the car with it alone for long periods of time, but it should power it long enough to know if its bad or not. I worked at a lot and had a few cars sitting with no batteries in them, whenever we needed to move them, we just hooked a jumper to them started them and moved them around with no battery (talkin about just a few seconds of movin)
Old Jun 24, 2010 | 06:05 AM
YviE's Avatar
YviE
Originally Posted by GS-power
Hi guys,
Looks like the battery isn't holding the charge. Get a new one and your problem should be solved.
It is strange your battery died within a year though...
akafixture
Mar 12, 2017 02:23 PM
vital
Aug 2, 2012 01:05 PM
guysfo
May 20, 2009 08:46 PM
vbacky
Mar 5, 2009 04:40 PM
